VW Golf TDI springt an geht wieder aus | Posts 16+
Go to page: Previous  1, 2
juster321
Post26-09-2010, 20:59    Subject: Quote
Okay, I'm assuming it's being promoted because the error doesn't always occur; it only happens after a longer period of inactivity and with larger temperature changes. VAG (Volkswagen Group) says nothing about the pump, and when it does run, it seems to work fine. So, how can I test the pump?
Translated on 18-07-2026, 2:48.
mserge
Post27-09-2010, 17:43    Subject: Quote
Are you absolutely sure it's not the immobilizer that's "turning off" the engine?
Does the immobilizer light flash if the engine has stalled?
If you want to restart it, does it make a meaningless noise or does it start up and then immediately shut off again?
neuer Turbo bei 200.000km
neue ESP bei 216.000km
verkauft mit 225000tkm
Clio 2 RS 170 PS BJ2003
Translated on 18-07-2026, 2:49.
Post27-09-2010, 20:18    Subject: Quote
Compare the coolant temperatures displayed in modules STG01 and STG17 (combination instrument). These are the two temperature readings from the dual sensor.
It would be interesting to know if on a given day, when there are with startup problems, both values are the same...
juster321
Post28-09-2010, 10:22    Subject: Quote
"It's not the fuse; the light goes out and stays off. Okay, let's see. Today it turned on again, so I'll test it again with the temperature sensors."
Just to let you know, when I turn the key to start the engine and hold it for a longer time, it takes about 10 seconds before it starts (if I don't hold it longer, it would shut off again).
Translated on 18-07-2026, 2:50.
mserge
Post28-09-2010, 10:57    Subject: Quote
Disconnect the temperature sensor and try starting it again. If it starts properly then, you've found the problem.
If that's not the case, as previously mentioned, there might be air in the fuel system that slowly escapes. Is your car parked horizontally or on a slope? If it's on a slope, turn it so the engine compartment is facing downhill. If it starts then, there's likely a leak in the fuel supply.
The last possibility would then be a problem with the ignition switch.
Translated on 18-07-2026, 2:51.
juster321
Post28-09-2010, 20:16    Subject: Quote
I also had the idea about using a ramp here in Berlin. I have it standing on a slight incline right now, and when it's tilted like that, it starts up in the morning regardless of whether the front is facing upwards or downwards. Where can I find the sensor that I need to disconnect? Are they the three sensors next to each other on the left side of the engine, or the G62 sensor at the back of the engine?
Translated on 18-07-2026, 2:52.
Post28-09-2010, 20:25    Subject: Quote
juster321 wrote:
or the g62 located at the rear of the engine?
vwSchrauber wrote:
The G62 sensor is located on the left side, when viewed from the direction of travel, near the water flange of the cylinder head. On the back, it has a two-pin connector with a plastic clip.
Yes.
Translated on 18-07-2026, 2:53.
juster321
Post28-09-2010, 20:32    Subject: Quote
juster321 wrote:
I've also had the idea about the hill, and I have one here in Berlin right now. When I had it positioned on the hill, it would start in the morning regardless of whether the front was facing up or down. Where can I find the sensor that I need to disconnect? Are they the three next to each other on the left side of the engine, or is it the G62 at the back of the engine?
I just noticed that the intake air temperature is at 25.2 degrees Celsius, even though it's only 11 degrees outside. Could this be related?
Translated on 18-07-2026, 2:54.
Post28-09-2010, 20:34    Subject: Quote
Waste heat from the engine?
Translated on 18-07-2026, 2:55.
mserge
Post28-09-2010, 21:17    Subject: Quote
Roger wrote:
Residual heat from the engine?
I think so too. That's why it would still start normally without any problems...
juster321
Post07-10-2010, 10:03    Subject: Quote
Okay, the temperature sensor (g62) has been replaced, but the problems with the fuel pump persist. Does anyone have any further input or ideas?
Translated on 18-07-2026, 2:56.
Hanswürstchen
Post10-10-2010, 14:49    Subject: Quote
I'm not very familiar with PD engines, but is the "Realis 109" issue still a problem in these vehicles?
Does the control unit receive a reliable power supply?
Is the CAN high and low connection between the ECU (Engine Control Unit) and the transmission intact?
Best regards.
juster321
dieselschrauber and H.Biernot likes this.
Post12-10-2010, 8:25    Subject: Quote
The problem has been found: the fuel injector in the fourth cylinder is defective and is drawing in air when the engine is idling. Thank you everyone for your help!
Translated on 18-07-2026, 2:57.
No new posts Document: Engine starts, then immediately stalls. Model: ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Documentary: Octavia 1 / Golf IV fuel gauge malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Sudden performance loss after restart, then okay again Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 2.0 TDI starts and then immediately shuts down.... Diesel Engine Technology
No new posts VW Golf III TDI: Engine Problems & No Start? Diesel Engine Technology
No new posts Motor geht springt schlecht an und geht an der Ampel aus Diesel Engine Technology
No new posts Seat Ibiza ASZ tdi startet und geht wieder aus Diesel Engine Technology
