A3 8P: Central Locking Not Working with Key
NoSleep
Post15-10-2010, 20:51    Subject: A3 8P: Central Locking Not Working with Key Quote
I'm having a problem with the central locking system on my 2005 A3 2.0T Ambition (2-door, with alarm).
When I open and close it using the remote control, everything works perfectly.
Even if I lock the vehicle with the key, the central locking system activates, providing both visual and audible confirmation, and the alarm system is armed.
However, if I try to unlock the vehicle with the key, only the mechanical lock is activated, so while the door opens, the other doors and the trunk remain locked.
The individual door opening is not coded - that would also apply to opening it with the remote control, right?
The strange thing is that the interior lights turn on when you unlock the car (not just when you open the door, mind you...).
Although I've modified some of the coding, I'm also experiencing this problem with the second car (an A3 8P '03 1.6 Ambition 2-door, without factory alarm, with the coding in its original state).
Since I've been aware of the issue with the microswitch since replacing the lock on the second car, I used VCDS to access the diagnostic data to check if the contact is being displayed correctly.
For this to work, the ignition must be on (otherwise, there will be no connection). However, the strange thing is that when the ignition is on, the central locking system receives the unlocking signal when I turn the key...
Both vehicles have already had the lock, including the microswitch, replaced.
In my case, it was 02/10 due to the persistent false alarms from the DWA (which didn't resolve the underlying problem), and in the second vehicle, it was at the end of 2008. The lock had no mechanical connection to the ignition cylinder.
I would prefer not to modify the code too extensively, so I would like to ask which part of the code might be causing this "error." I'm actually ruling out an electrical problem, since the lock responds within the KSTG measurement block when it's closing.
Code:
Mittwoch,13,Oktober,2010,18:53:34:48582
VCDS Version: RKS 10.6.1
Datenstand: 20100901
Robert
Fahrzeugtyp: 1K0
Scan: 01 02 03 08 09 15 16 17 19 25 37 42 44 46 47 52 55 56 69 76
          77
Fahrzeug-Ident.-Nr.: WAUZZZ8P96A041648   Kilometerstand: 55200km
00-Lenkwinkelsensor -- Status: OK 0000
01-Motor -- Status: OK 0000
02-Getriebe -- Status: OK 0000
03-Bremsen -- Status: OK 0000
08-Klima/Heizung -- Status: OK 0000
09-Bordnetz -- Status: OK 0000
15-Airbag -- Status: OK 0000
16-Lenkrad -- Status: OK 0000
17-Kombiinstrument -- Status: OK 0000
19-CAN-Gateway -- Status: OK 0000
25-Wegfahrsperre -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Türelektr. Fahrer -- Status: OK 0000
44-Lenkhilfe -- Status: OK 0000
46-Komfortsystem -- Status: OK 0000
47-Soundsystem -- Status: OK 0000
52-Türelektr. Beifahr. -- Status: OK 0000
55-Leuchtweitenreg. -- Status: OK 0000
56-Radio -- Status: OK 0000
69-Anhänger -- Status: OK 0000
76-Einparkhilfe -- Status: OK 0000
77-Telefon -- Status: OK 0000
Adresse 01: Motor        Labeldatei: RKS\06F-907-115-AXX.lbl
   Teilenummer SW: 8P0 907 115 A    HW: 8P0 907 115 A
   Bauteil: 2.0l R4/4V TFSI G00 0150
   Revision: --H01---    Seriennummer: AUX7Z0E6FNM07C
   Codierung: 010300031C070160
   Betriebsnr.: WSC 06314 000 00000
   VCID: 306B7FA6DA51
Keine Fehler gefunden.
Readiness: 0010 0001
Adresse 02: Getriebe        Labeldatei: RKS\02E-300-0xx.lbl
   Teilenummer SW: 02E 300 042 Q    HW: 02E 927 770 AE
   Bauteil: GSG DSG         070 0928
   Revision: 04507000    Seriennummer: 00000507060459
   Codierung: 0000020
   VCID: 214D8AE281BB
Adresse 03: Bremsen        Labeldatei: RKS\1K0-614-517-MK60-F.lbl
   Teilenummer SW: 1K0 614 517 R    HW: 1K0 614 517 R
   Bauteil: ESP FRONT MK60-AT   0103
   Revision: 00T12001
   Codierung: 0053890
   Betriebsnr.: WSC 60992 150 83573
   VCID: 366749BE3835
Adresse 08: Klima/Heizung        Labeldatei: RKS\8P0-820-043.lbl
   Teilenummer SW: 8P0 820 043 L    HW: 8P0 820 043 L
   Bauteil: KlimavollautomatH16 0200
   Revision: 019157      Seriennummer: 8P0820043L
   VCID: 35654EB22533
Adresse 09: Bordnetz        Labeldatei: RKS\8P0-907-279-23-H.lbl
   Teilenummer SW: 8P0 907 279 F    HW: 8P0 907 279 F
   Bauteil: Bordnetz-SG     H36 1201
   Revision: 00H36000    Seriennummer: 00000002084364
   Codierung: E58E5F078414101400000000000000000008FE175C0200
   Betriebsnr.: WSC 75230 146 86657
   VCID: 408B2F666AF1
   Teilenummer: 8P1 955 119 B
   Bauteil: Wischer AU350   H01 0130
   Codierung: 00062736
   Teilenummer: 4E0 910 557
   Bauteil: REGENLICHTSENSORH10 0050
   Codierung: 00150573
Adresse 15: Airbag        Labeldatei: RKS\8P0-959-655-94.lbl
   Teilenummer SW: 8P0 959 655 H    HW: 8P0 959 655 H
   Bauteil:    Airbag 9.41  H11 3520
   Revision: 91H1135    Seriennummer: 0037W000DZKO
   Codierung: 0070612
   VCID: 4799347A4FDF
Adresse 16: Lenkrad        Labeldatei: RKS\8P0-953-549.lbl
   Teilenummer SW: 8P0 953 549 E    HW: 8P0 953 549 E
   Bauteil: Lenksäulenmodul H34 0070
   Codierung: 0011142
   VCID: 408B2F666AF1
   Teilenummer: XXXXXXXXXXX
   Bauteil: Lenkradmodul    H03 0080
Adresse 17: Kombiinstrument        Labeldatei: RKS\8P0-920-xxx-17-MY7.lbl
   Teilenummer SW: 8P0 920 930 T    HW: 8P0 920 930 T
   Bauteil: KOMBIINSTR. VDO H80 0460
   Revision: D03         Seriennummer: 2246ED03003366
   Codierung: 0000013
   Betriebsnr.: WSC 75230 146 178883
   VCID: 4381206A7BE7
Adresse 19: CAN-Gateway        Labeldatei: RKS\1K0-907-530.lbl
   Teilenummer SW: 1K0 907 530 H    HW: 1K0 907 951
   Bauteil: J533__Gateway   H12 0150
   Revision:   H12       Seriennummer: 3100106713829D
   Codierung: 7F0F47CA07000100
   VCID: 2C536BD6F679
Adresse 25: Wegfahrsperre        Labeldatei: RKS\1K0-920-xxx-25.lbl
   Revision: D03         Seriennummer: AUX7Z0E6FNM07C
   VCID: 4381206A7BE7
Adresse 37: Navigation        Labeldatei: RKS\8E0-035-192-RNSE.lbl
   Teilenummer SW: 8P0 035 192 A    HW: 8P0 035 192 A
   Bauteil: RNS-E HIGH EU   H70 0650
   Revision:      01S    Seriennummer: AUZBZ7E0903364
   Codierung: 0205711
   VCID: 2D5566D2CD63
Adresse 42: Türelektr. Fahrer        Labeldatei: RKS\8P0-959-801-MAX1.lbl
   Teilenummer: 8P0 959 801 F
   Bauteil: Tuersteuerger.  H10 0040
   Codierung: 0000120
   VCID: 3E77519E1005
Adresse 44: Lenkhilfe        Labeldatei: RKS\1Kx-909-14x.lbl
   Teilenummer: 1K0 909 144 J
   Bauteil: EPS_ZFLS Kl. 000    3001
   Revision: 00H17000
   VCID: 316D7AA2D15B
Adresse 46: Komfortsystem        Labeldatei: RKS\8P0-959-433.lbl
   Teilenummer: 8P0 959 433
   Bauteil:    KSG          H03 0040
   Codierung: 188000587F280C0DC88AC65300
   VCID: F9FD0282C9AB
   Teilenummer: 1K8 951 605
   Bauteil: LIN BACKUP HORN H09 9002
   Teilenummer: 1K0 907 719 C
   Bauteil: Neigungssensor  005 0003
   Teilenummer: 8P0 951 177
   Bauteil: Innenraumueberw.H03 0020
Adresse 47: Soundsystem        Labeldatei: RKS\8Px-035-382.lbl
   Teilenummer SW: 8P3 035 382     HW: 8P3 035 382
   Bauteil: AB2 SUBWOOFERBOXH25 0160
   Revision: 00003       Seriennummer: 10000001265970
   VCID: F0EB3FA69AD1
Adresse 52: Türelektr. Beifahr.        Labeldatei: RKS\8P0-959-802-MAX1.lbl
   Teilenummer: 8P0 959 802 F
   Codierung: 0000120
   VCID: 3F892C9A170F
Adresse 55: Leuchtweitenreg.        Labeldatei: RKS\8P0-907-357.lbl
   Teilenummer: 8P0 907 357 C
   Bauteil: Dynamische LWR  H01 0010
   Revision: 00000000    Seriennummer:
   Codierung: 0000001
   VCID: 3A7F5D8E0C2D
Adresse 56: Radio        Labeldatei: RKS\8E0-035-192-RNSE.lbl
   Codierung: 0205711
   VCID: 2D5566D2CD63
Adresse 69: Anhänger        Labeldatei: RKS\8P0-907-383.lbl
   Teilenummer SW: 8P0 907 383     HW: 8P0 907 383
   Bauteil: ANHAENGERELEKTR H01 0010
   Codierung: 0000001
   VCID: F6E709BEF8B5
Adresse 76: Einparkhilfe        Labeldatei: RKS\8P0-919-283.lbl
   Teilenummer SW: 8P0 919 283 A    HW: 8P0 919 283 A
   Bauteil: Parkhilfe 4-Kan H09 0010
   Revision: 00H09000    Seriennummer: 00067824820519
   Codierung: 0011003
   VCID: 397D4282092B
Adresse 77: Telefon        Labeldatei: RKS\8P0-862-335.lbl
   Teilenummer SW: 8P0 862 335 C    HW: 8P0 862 335 C
   Bauteil: FSE_255x BT     H18 0160
   Revision: 00000001    Seriennummer: 00000000277191
   Codierung: 0010311
   VCID: 366749BE3835
Ende   --------------------------------------------------------------------
Thank you for the support and a wrinkle-free winter icon_smile.gif.
"Addendum:"
I was led to believe that there's a way to disable the alarm system using coding. There's a setting, "DWA," that can only be deactivated via the diagnostic interface/transponder. If I deactivate it, I can lock and unlock the car while the alarm is disarmed, and the central locking system responds. However, as soon as the "DWA" is activated, I can only open and close the doors mechanically. When this setting is active, the central locking system also responds to the key when the alarm is armed. If I open the door mechanically, the alarm system triggers.
Translated on 02-10-2026, 13:33.
Post17-10-2010, 18:28    Subject: A3 8P: Central Locking Not Working with Key Translating...
[Translating...]
/viewtopic.php?t=23399&highlight=caddy
No new posts Roomster Tailgate Won't Open: Remote Button Issue Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 Door Auto Open/Close Problem (8L) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts DPF not regenerating Troubleshooting & Guides
No new posts Central Locking: Rear Doors Won't Open? Electrical Systems, Vehicle Electronics, Multimedia
No new posts EDC15: AEL/ACV/AJT Engine - ELAB Not Opening Diesel Engine Technology
No new posts Passat 3B Rear Door Won't Open? Transmission, Chassis, Body & Interior
No new posts VW Passat Driver Door Won't Open - Fix! On-Board Diagnostics (OBD)
