Audi 80 B4 Steering Rack - Replacement
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
Karma: +1336 / -0   Thank you, like it!
Post21-09-2010, 21:59    Subject: Audi 80 B4 Steering Rack - Replacement Quote
What is the best way to check the head bearing supports for wear on a vehicle? Vehicle: Audi 80 Avant B4.
Using a lever between the bearing support and the stabilizer bar, I can move the axle to the left and right against tension (it springs back). The car is resting on its wheels, and the handbrake is not engaged. The amount of force required is comparable on both the left and right sides. Unfortunately, the repair manual and other manuals don't provide any information on this.
"The TÜV (German technical inspection agency) didn't find any issues last year. I'm asking because I have a vehicle alignment scheduled for another reason, and it's not supposed to be because of worn-out rear suspension components."
Translated on 06-09-2026, 3:13.
mdonau
1988 Audi 80
Post21-09-2010, 22:04    Subject: Audi 80 B4 Steering Rack - Replacement Quote
visual inspection:
-Rubber torn?
-Are the inner and outer parts still connected by the rubber?
HA-lager rarely break.
Best regards, Michael.
Passat 3B AFN Syncro, E46 330D, T3 1,7TDI, T3-Syncro TD
Translated on 06-09-2026, 3:15.
Post21-09-2010, 22:33    Subject: Audi 80 B4 Steering Rack - Replacement Quote
When installed, the bearings appear to be in good condition. However, the bearing supports obscure everything, so you can only see the actual condition of the rubber bearings after removing them from the supports. To do this, I would have to disconnect the brake lines and remove the brake force regulator. I wanted to avoid that, because if I had to do that, I would probably just replace the bearings anyway.
Translated on 06-09-2026, 3:16.
Karma: +643 / -0   Thank you, like it!
Post01-11-2010, 13:36    Subject: Audi 80 B4 Steering Rack - Replacement Quote
Go to the TÜV/Dekra inspection center and have your car tested on the shaker plate.
wolfi_b
Post04-11-2010, 8:05    Subject: Audi 80 B4 Steering Rack - Replacement Quote
You can't force those things in yourself (unless you have a special tool or press), they're quite large and very difficult to insert.
1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
Translated on 06-09-2026, 3:17.
No new posts {SOUND_TYPE}: Rumble {VEHICLE_MODEL}: Audi A3 8P Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake fluid change Audi A4 8K Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi Engine Codes: Types, MKB, GKB, AKB, MJ Technical Data
This topic is locked, you cannot edit or reply. Audi 80 B4: Replacing Headlight Adjustment Motor Transmission, Chassis, Body & Interior
No new posts Audi 80 RS2 Steering Wheel Controls: Same as Audi A4 B5? Transmission, Chassis, Body & Interior
No new posts FIS in the Audi Transmission, Chassis, Body & Interior
No new posts 2L TDI mit 170 PS im Audi A4 B7 Diesel Engine Technology
