Winterreifen optimal ausnutzen? | Posts 48+
Go to page: Previous  1, 2, 3, 4
Karma: +1100 / -0   Thank you, like it!
Post03-11-2010, 19:58    Subject: Quote
I had it (prepared) with reference to the appendix of the draft resolution. I do not have the original document (303 pages), but only the commentary – which is what the esteemed member of parliament would also only read. icon_rolleyes.gif
Translated on 03-08-2026, 1:16.
Post04-11-2010, 8:12    Subject: Quote
ulf wrote:
Hutfahrer wrote:
Winter tires are allowed to be a maximum of 6 years old during their entire period of use (i.e., throughout the entire winter) and must have at least 4 mm of tread depth. . .
Hmm, that's not the case here.
http://www.bundesrat.de/cln_161/nn_8694/SharedDocs/Drucksachen/2010/0601-700/699-10,templateId=raw,property=publicationFile.pdf/699-10.pdf
explicitly nothing (more) to read.
Does Annex II of Directive 92/23/EEC perhaps contain exactly these requirements?
Below.
http://eur-lex.europa.eu/LexUriServ/LexUriServ.do?uri=CONSLEG:1992L0023:20060101:DE:HTML#E0010
Can I see Appendix II?
Regarding "
", the following applies: In the context of this directive, it means:
2.2. "M+S Tires": Tires whose tread pattern and structure are designed to provide better driving characteristics primarily in mud and fresh or melting snow compared to normal tires. The tread pattern of M+S tires is generally characterized by larger grooves and/or lugs, which are separated by larger spaces than those found on normal tires.
Bitte gib mir den deutschen Text, den du übersetzt haben möchtest.
3.1 The tires must bear the following markings:
3.1.5. the letters "M + S" or "M.S" or "M & S" on M + S tires;
Nothing mentioned about an increased minimum tread depth or age limit for M+S tires.
It is also completely beyond my comprehension how, based on this, they intend to drive products like China-SR with M+S markings out of the market icon_rolleyes.gif.
Translated on 03-08-2026, 1:19.
Post04-11-2010, 11:35    Subject: Quote
DDP reports: The reading has been postponed to November 26, 2010. Further revisions are needed.
Translated on 03-08-2026, 1:21.
No new posts VTG & AGR: Optimize Coordination for Success Diesel Engine Technology
No new posts Relais 109: Optimize Starting with Lighting Diesel Engine Technology
No new posts Winter tires for VW Polo 9N:-( Transmission, Chassis, Body & Interior
No new posts Continental Winter Tires Transmission, Chassis, Body & Interior
