22-11-2010, 8:15 Subject: Fogger Replacement G6+ |
Hi.
Can anyone with experience using the "Aktuelle Kuh" software tell me how to replace the Nebler (fog machines) on the G6+?
Possibly also the middle or lower grill, to install the "chrome grille" there.
My dad already felt a sharp pain, like a kidney stone attack, in his lower back after only 4 weeks.
Translated on 07-08-2026, 21:08.
Profile PM Garage |
bloesch Profi-Schrauber
Joined: 03/18/2005 Posts: 622 Karma: +16 / -0 Location: FL
22-11-2010, 19:24 Subject: Fogger Replacement G6+ |
NSW:
Detach the grid, remove the screw -> and there you have it.
As far as I know, the grid at the bottom center is also just clipped in place and should be pulled forward to remove it.
Translated on 07-08-2026, 21:09.
22-11-2010, 19:50 Subject: Fogger Replacement G6+ |
So, only clipped?
Not like with the 1K/3C, where you use a screw and then clip it in place?
I don't want to tear it apart right away...
Translated on 07-08-2026, 21:10.
Profile PM Garage |
Roger Profi-Schrauber
Joined: 10/11/2002 Posts: 3035 Karma: +88 / -0 Location: Rodgau 2017 Volkswagen Golf Premium Support
22-11-2010, 20:21 Subject: Fogger Replacement G6+ |
It's only partially obscured.
The middle section is simply clipped in place.
Translated on 07-08-2026, 21:11.
Profile PM Garage |
22-11-2010, 20:35 Subject: Fogger Replacement G6+ |
Then I'll rip both of the fog lights out.
The left fog light is being replaced, and the center grille will be fitted with a chrome trim piece.
Haha, the original parts tuner is at it again  .
EDIT: The original part tuner doesn't want to incur costs: https://community.dieselschrauber.org/en/viewtopic.php?t=24060
Translated on 07-08-2026, 21:12.
Profile PM Garage |
30-11-2010, 12:14 Subject: Fogger Replacement G6+ |
Here's the killer grille, which I finally managed to get out after about 20 minutes of fiddling.
Some of the violence and, especially, figuring out where the clips were located was very time-consuming.
| Description: |
| File size: |
169.33 KB |
| Viewed: |
1048 times |
Profile PM Garage |
