Wastegate Turbocharger Connection: 1Z/AHU & More
Deus Violentia
Post16-12-2010, 13:47    Subject: Wastegate Turbocharger Connection: 1Z/AHU & More Quote
Please take a look at these three pictures.
I found this statement by dieselmartin that seems to match my image, BUT in Ulf's technical article, the graphic for the wastegate turbocharger looks different. The colored image matches my black and white graphic. Which one is correct?
dieselmarin ANALOG to my image:
N75 Black - LOCATION: Underside / on the air filter housing or on the thick plastic pipe leading to the turbo.
Connect the red wire to the turbocharger / connect the other side to the TOP of the N75 valve.
Blue wire to the wastegate / connect the other side SIDEWAYS to the N75 valve.
P.S.: I assume that Ulf has made a mistake icon_cool.gif.
Okay, I'm ready. Please provide the German text you want me to translate into English. Just paste it here, and I will give you the translation.
BKD GRF
AHF EBF
Translated on 14-08-2026, 20:54.
Post16-12-2010, 14:49    Subject: Wastegate Turbocharger Connection: 1Z/AHU & More Quote
In the book "Now I'll do it myself," there's a mention that there were TWO different types of connectors.
I can check my pictures of cleaning the exhaust manifold or looking at the golf club if there's a need.
Where exactly do you see the contradiction?
The direction of flow shouldn't actually matter; you just shouldn't "reverse the phase."
Translated on 14-08-2026, 20:56.
Deus Violentia
Post16-12-2010, 16:20    Subject: Wastegate Turbocharger Connection: 1Z/AHU & More Quote
I don't see any contradiction; I just encountered one of those frustrating situations again.
And it's throwing out a "00575 intake manifold pressure control differential" error. I've replaced all the rubber hoses (they looked like Dresden in 1945, including the ones inside the engine compartment icon_smile.gif), and I think that the previous owners (quote: "it never worked properly..." icon_rolleyes.gif icon_rolleyes.gif icon_rolleyes.gif) simply connected everything backward, meaning they swapped the boost pressure and atmospheric pressure connections.
That would explain why the car occasionally goes into limp mode. The charger is supposedly only 2 years old, so I think the wastegate is probably okay, and the boost pressure is also being achieved (according to the logs).
Yesterday, I wasn't sure, so I looked it up and just discovered the contradiction.
"@Dieselmartin: It would be extremely helpful if you could take a closer look at your pictures. The 1Z is from a Golf III, manufactured up to 1994/1995, because it has an external height sensor."
Does the "Jetzt mach ich's mir selbst" book include a template or guide for that?
BKD GRF
AHF EBF
Translated on 14-08-2026, 20:58.
Post16-12-2010, 16:24    Subject: Wastegate Turbocharger Connection: 1Z/AHU & More Quote
I can provide images and live tracking data for a G3 Var. manufactured in December 1995 (model year 1996).
I browsed through some pictures tonight.
Translated on 14-08-2026, 21:00.
Deus Violentia
Post16-12-2010, 16:27    Subject: Wastegate Turbocharger Connection: 1Z/AHU & More Quote
Live-Debugging of Golf III is urgently requested, esteemed sir. icon_lol.gif --> THANK YOU THANK YOU!
BKD GRF
AHF EBF
Post16-12-2010, 16:35    Subject: Wastegate Turbocharger Connection: 1Z/AHU & More Quote
Initial successes:
The red line connects to the compressor outlet.
blue to the pressure sensor.
Therefore, "schwarz" is currently an ATM.
Don't be surprised, it IS a 1Z icon_wink.gif.
 File size:  315.95 KB
 Viewed:  4022 times
Translated on 14-08-2026, 21:01.
Deus Violentia
Post16-12-2010, 20:23    Subject: Wastegate Turbocharger Connection: 1Z/AHU & More Quote
Hmm, unfortunately, I can't access the black line!
BKD GRF
AHF EBF
Translated on 14-08-2026, 21:02.
Post16-12-2010, 20:48    Subject: Wastegate Turbocharger Connection: 1Z/AHU & More Quote
Damn.
I got rid of that "do-it-yourself" attitude when I sold the Volkswagen Golf.
Karma: +1344 / -0   Thank you, like it!
Post16-12-2010, 23:41    Subject: Wastegate Turbocharger Connection: 1Z/AHU & More Quote
In my documentation, the connection for the N75 valve is shown differently depending on the type of control unit, but both are different from the image in your catalog.
"By 'above,' we mean the side with the two connectors."
The side connection (labeled "top") always connects to the pressure chamber.
For MSG 8A0 907..., the upper hose connects to the air filter, while the lower hose connects to the charger (supercharger).
For MSG 028 906..., the "upper" hose connects to the suction line, while the lower hose connects to the pressure port on the charger. That's how it's installed in my setup.
"Edit: The image for my machine in the catalog (VAG Cat Board) is incorrect. Hoses 18 and 19 need to be swapped."
Translated on 14-08-2026, 21:03.
Deus Violentia
Post17-12-2010, 9:08    Subject: Wastegate Turbocharger Connection: 1Z/AHU & More Quote
What does this imply in reverse? This means that the default valve position must be different depending on the control unit, otherwise the whole system wouldn't work.
Hmm, it seems that Ulf was actually right all along icon_lol.gif.
BKD GRF
AHF EBF
Translated on 14-08-2026, 21:05.
Post17-12-2010, 9:33    Subject: Wastegate Turbocharger Connection: 1Z/AHU & More Quote
Okay.
I had the 028 906 021 AF (?) (MSA12) and a "modified" MSA15.
I never modified the N75, and based on my picture, I would say:
red - compressor - N75 valve (top)
blue - pressure sensor - N75 page.
black - ATM - N75 valve (bottom)
The device was pulled with 1.1 bar and the appropriate amount of icon_twisted.gif.
Sure, here's the translation:
"Take a look:"
/viewtopic.php?t=5218&highlight=n75+rattling
I'm currently looking for this particular image of mine.
http://www.google.de/imgres?imgurl=http://people.freenet.de/golf-schrauber/Magnetventil.jpg&imgrefurl=/viewtopic.php%3Ft%3D3431&usg=__0XpTSH3zlnGBBxmt9xg50oWhN7o=&h=404&w=539&sz=62&hl=de&start=1&zoom=1&um=1&itbs=1&tbnid=jubLqYzNnlxW3M:&tbnh=99&tbnw=132&prev=/images%3Fq%3Dmagnetventil%2B1z%26um%3D1%26hl%3Dde%26client%3Dfirefox-a%26sa%3DN%26rls%3Dorg.mozilla:en-US:official%26tbs%3Disch:1
Translated on 14-08-2026, 21:07.
Post17-12-2010, 10:12    Subject: Wastegate Turbocharger Connection: 1Z/AHU & More Quote
Hi Martin,
I still have it, and I specifically checked yesterday.
But it's very easy to check:
- N75 valve with no voltage applied (unplugged): Continuity detected between the turbocharger and the pressure sensor!
Translated on 14-08-2026, 21:09.
Post17-12-2010, 11:04    Subject: Wastegate Turbocharger Connection: 1Z/AHU & More Quote
Sure, it should be fail-safe.
Then the pressure gauge will read 0.6 bar.
Otherwise, after the power outage, the turbo is also gone icon_smile.gif.
Translated on 14-08-2026, 21:10.
Deus Violentia
Post17-12-2010, 11:17    Subject: Wastegate Turbocharger Connection: 1Z/AHU & More Quote
Now some light is being shed on the dark corners of this theory... I'll investigate and report back to you!
BKD GRF
AHF EBF
No new posts VTG Loader: Operating principle and settings Technical Articles
No new posts Upgrade Turbo: Wastegate to VTG Turbocharger Diesel Engine Technology
No new posts Wastegate Air Valve: VTG Turbocharger Explained Diesel Engine Technology
No new posts Wastegate Question: Troubleshooting & Explained Diesel Engine Technology
