A4 B5 Quattro Instrument Cluster
klahaui
Avatar-klahaui
2019 Volkswagen Golf
Post17-12-2010, 20:41    Subject: A4 B5 Quattro Instrument Cluster Quote
Hello everyone,
While it's a gasoline engine, I don't think that's a major issue in this case.
My acquaintance bought the vehicle, knowing that the AI (artificial intelligence) system was defective.
"The indicator lights occasionally illuminate without a clear reason. The mileage reading changes randomly; he received a note from Audi stating that the error was read from the memory."
Control unit: 8 y 919 03 y
Encoding 00063.
Workshop code: WSC 65543.
65535 - Control unit defective.
00-00 - -
That's what it says on the note.
It makes me a bit suspicious, as I suspect it might also be a mileage counter.
Is it really true that his STG (Steuergerät) is defective, or is there still a chance to fix it?
Happy Friday!
Greetings.
Thilo.
EDIT: It's a 1994 model, but it has been modified with facelift parts. Presumably, the instrument cluster (KI) has also been replaced.
"Or was the larger BC already available in the year 1994?"
Translated on 06-10-2026, 21:45.
Ross-Tech-Support
Post18-12-2010, 11:26    Subject: A4 B5 Quattro Instrument Cluster Quote
When it comes to used cars, there are always obvious issues, and in the end, many people sing the familiar song...
The part number in the log doesn't match, so it's possible that the memory content is corrupted. However, it's best to simply read the data again from scratch and see. The control unit doesn't store the entry with the value 65535 for no reason, and sometimes it might be possible to recover something. However, whether it's worth it given the vehicle's age is a different question.
Translated on 06-10-2026, 21:47.
No new posts Document A3 8P1 Quattro up to week 34.04, fuel tank noises. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat combination instrument cluster 05.99 to 09.2000 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat combination instrument cluster 1998 to 04.99 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts TD 89/B3 Conversion: Upgrade to Quattro Diesel Engine Technology
No new posts A4 Avant B5 2.5 TDI Quattro: Buying Guide Diesel Engine Technology
No new posts Audi A6 2.5 TDI AKE Quattro fuel injection quantity Diesel Engine Technology
No new posts Audi A6 3.0 TDI Timing Chain Replacement Diesel Engine Technology
