AFN intake manifold pressure error code
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
gogizmo
Karma: +0 / -1   Thank you, like it!
Post07-12-2010, 22:53    Subject: AFN intake manifold pressure error code Quote
Hello everyone,
We're having the following problem with the AFN (1.9L 110HP) engine swap in my girlfriend's Volkswagen Golf. The engine constantly has an error code stored in the error memory that cannot be cleared.
"1 error found:"
00575 - Intake manifold pressure.
17-00 - Rule difference.
What could cause this error, and what is the best way to determine its exact source? Would it be possible to narrow down the cause of the error by recording sensor readings during a test drive? If so, which gauge blocks would be most helpful?
Then I have another question: What could be the reason why I can no longer read the engine control unit (ECU) data when driving above approximately 100 km/h? It will only work again when we slow down.
Perhaps you could help me.
Translated on 07-07-2026, 5:35.
mullemaus
Post08-12-2010, 20:21    Subject: AFN intake manifold pressure error code Quote
Did you REALLY use the search function? With this type of error message, one can do a 'stepp-dance' here in the forum. icon_confused.gif icon_wink.gif
Translated on 07-07-2026, 5:36.
elektronik-jojo
Post17-12-2010, 20:40    Subject: AFN intake manifold pressure error code Translating...
[Translating...]
LMM
Ross-Tech-Support
Post18-12-2010, 12:30    Subject: AFN intake manifold pressure error code Quote
While mullemaus has already pointed out the search function, here's the link again, just in case...
Okay, I understand. Please provide the German text you want me to translate into English. I will only provide the translation.
...while I wouldn't completely rule out the LMM as a cause of the error, based on my experience, it's quite unlikely. icon_wink.gif
Translated on 07-07-2026, 5:37.
No new posts VTG Issues: Emergency Mode, Intake Manifold Pressure Regu... Troubleshooting & Guides
No new posts Glow Plug Indicator Flashing: Error Code Questions Diesel Engine Technology
No new posts Golf 4 TDI springt nicht an! Kein Fehlerspeichereintrag! Diesel Engine Technology
No new posts V6 TDI Saugrohrdruck Diesel Engine Technology
No new posts Intake Manifold Pressure: Regulation & Mass Air Flow? On-Board Diagnostics (OBD)
