Where is the thermostat located on a TDI BLS Golf 5?
flightmaster
Post19-12-2010, 19:18    Subject: Where is the thermostat located on a TDI BLS Golf 5? Quote
The thermostat in my Golf TDI.
MKB- BLS, year of manufacture 2007
is defective and needs to be replaced urgently.
I have the 'So wirds gemacht' guide, but it doesn't describe the installation position or the replacement process.
Can anyone help me with this?
Images, links, instructions – everything is welcome.
The workshop is not an option; the warranty has expired.
I've already done this replacement on a Golf 4 before, and it wasn't a problem.
Thank you in advance.
Translated on 04-07-2026, 21:06.
Post19-12-2010, 20:09    Subject: Where is the thermostat located on a TDI BLS Golf 5? Quote
Without knowing the exact BLS engine... is it located in the same place as on all 1.9 PD TDI engines? Specifically, near the water pump, towards the crossmember, under a coolant flange? Is anything built there already?
Translated on 04-07-2026, 21:07.
wingmaster
Avatar-wingmaster
Post21-12-2010, 1:06    Subject: Where is the thermostat located on a TDI BLS Golf 5? Quote
The thermostat in the BLS model is located under the alternator, within the coolant flange.
Translated on 04-07-2026, 21:08.
flightmaster
Post23-12-2010, 18:53    Subject: Where is the thermostat located on a TDI BLS Golf 5? Quote
I changed it today, and it was quite easy. Just draining the coolant is a messy job.
But...
I'm just shocked... I'm checking the part numbers again.
On the packaging (Behr), the number: 1.186.87.320 is printed (it is for...). Golf 4.
According to the Behr catalog, a suitable thermostat for a Golf 5 BLS should have the part number: 1.173.87.300.
Does this cause any problems? It certainly worked for me. Where are the differences? The dimensions, etc. The opening temperatures are identical.
The parts dealer sold me the wrong part. I'm going to lose it if I have to do this crap again.
Help, does anyone here know anything about this, or can someone take a look at the shelf and point out the differences?
Please, please, have another breakdown.
Translated on 04-07-2026, 21:09.
Post23-12-2010, 20:24    Subject: Where is the thermostat located on a TDI BLS Golf 5? Quote
For which G4 model is this?
I don't see any overlaps.
I would say it's wrong.
The first BKC had one from the G4 series - but you have a BLS.
Translated on 04-07-2026, 21:11.
flightmaster
Post23-12-2010, 21:17    Subject: Where is the thermostat located on a TDI BLS Golf 5? Quote
I consulted the 'Behr catalog.'
After that, it's clearly wrong.
Unfortunately, I only checked it after I had already finished working on it for 2 hours, and now I'm just lying on the couch.
You tend to trust the nice gentleman behind the counter to some extent.
As far as I know, the BLS is a BKC with a particulate filter.
The question is, 'Ganze Aktion', do we do it all over again, or 'Drin lassen'
I cannot translate this as it appears to be a string of question marks.
Post23-12-2010, 21:29    Subject: Where is the thermostat located on a TDI BLS Golf 5? Quote
I would have said the same thing.
And the specified temperatures are also the same.
I can't really say whether I'm for or against it – I'm more of a numbers person, always checking all the figures.
But 2 hours isn't really that long.
Translated on 04-07-2026, 21:13.
flightmaster
Post29-12-2010, 1:37    Subject: Where is the thermostat located on a TDI BLS Golf 5? Quote
I replaced the thermostat today with the correct one.
While the dimensions are the same, the wax capsule in the BLS product is only half as thick as the other one.
'I don't know what good this exchange frenzy did, but I'm certainly glad to have an 'original' one again.'
Unfortunately, the preheating indicator is flashing this afternoon, and the dashboard display says 'Visit workshop.'
Error read: Spark plug, cylinder 1, interruption.
Candle out, sooty black.
Back to the parts dealer. 16 euros per piece. He probably works as a pharmacist on the side.
I've already replaced these, and I'll order 3 more online sometime.
Is it normal for glow plugs to fail after 100,000 km?
Translated on 04-07-2026, 21:14.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post29-12-2010, 9:41    Subject: Where is the thermostat located on a TDI BLS Golf 5? Quote
My icon_lol.gif has lasted 60,000 km, so be happy with 100,000 km.
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Translated on 04-07-2026, 21:15.
No new posts Golf 1J: GRA Failure When Turn Signal Is On Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing belt replacement on a 1.9L PD TDI Troubleshooting & Guides
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Thermostat: Buy, Install, Repair & More Diesel Engine Technology
No new posts Thermostat V6 TDI Diesel Engine Technology
No new posts Thermostat: G62, G83 Coolant Temp. Issues On-Board Diagnostics (OBD)
No new posts Coolant Temperature Difference: Thermostat vs. Sensor Diesel Engine Technology
