CR TDI: Inactive Sensor Data Blocks 2.0
Martin L.
Post04-01-2011, 9:43    Subject: CR TDI: Inactive Sensor Data Blocks 2.0 Quote
Hello everyone,
I tried to read the engine's diagnostic data on my Octavia Scout 2.0 CR TDI, but the 'Diagnostic Data' button is grayed out and I can't access it.
This only applies to the engine control unit. I can read out all other control units.
I can also access the configuration of the MSG. There are no errors logged.
Am I doing something wrong, or is there a problem with a gateway? By the way, I've installed the latest update.
Thank you!
Translated on 24-10-2026, 21:13.
Post04-01-2011, 11:20    Subject: CR TDI: Inactive Sensor Data Blocks 2.0 Quote
Please perform a complete vehicle scan.
Translated on 24-10-2026, 21:14.
Post04-01-2011, 11:48    Subject: CR TDI: Inactive Sensor Data Blocks 2.0 Quote
It's normal; newer engine control units instead provide "expected values." Simply click the corresponding button to the right in VCDS.
No new posts VE Injection Pump Data: 5-Cylinder Engine Performance Technical Data
No new posts VE Injection Pump Data: 4-Cylinder Engine Performance Technical Data
No new posts PD Injector Data: 4-Cylinder Engine Performance Technical Data
No new posts G60 Measurement Blocks: Specs & Applications Diesel Engine Technology
No new posts Measurement blocks 1Z On-Board Diagnostics (OBD)
No new posts Measurement blocks A6 2.5 TDI V6 Diesel Engine Technology
No new posts Measurement blocks On-Board Diagnostics (OBD)
