I just thought, my BMR (basal metabolic rate) wants to "go for a walk," meaning it's in the process of regenerating.
070.2 Regeneration time = 644 seconds.
The loading coefficient of 33%, as indicated by code 068.1, also suggested this.
Okay, let's hit the country road.
But nonsense. He didn't want to. Apparently, he decided that "a little regeneration" would be enough 33 km ago (073.2), because he absolutely refused to add more fluid.
I always thought that regeneration could only happen completely.
At most, they were "intended to be complete," but they were unsuccessfully discontinued.
070.3 unsuccessful registration, but = 0.
I found it interesting that the 068.3 Aschelern value, which was below 5% for the first time, was -1.8%.
tütü... as you know, I already wrote to you about the negative ash return value. Then, one day later, I checked again and the value was at -6.5%?! I've covered 190km since the regeneration, and the load is already over 30% again...
'If the regeneration attempts are unsuccessful, there will be no data recorded. I'm just wondering how someone can achieve that with over 80,000 km if the car isn't driven on long distances... or does he reset the counter after a successful regeneration?'
