Motorsteuergerät keine Kommunikation nach VW Update | Posts 16+
Go to page: Previous  1, 2
Post21-01-2011, 20:39    Subject: Quote
slg60 wrote:
Okay, it's working again. I now have version 6655. It drives noticeably differently now, but not necessarily in a negative way. It's a subjective impression! There was also a shift recommendation in the MFA+, I don't know what it has to do with the MSTG, but it must be that way, otherwise I wouldn't have it!
So, is there really something new in it now icon_eek.gif?
The shift indicator actually depends on the MSG-SW status. However, it's only really useful for detecting engine over-revving, as it then recommends using lower gears. Otherwise, you can ignore it; it indicates that at 1,300/min in 5th gear while going slightly uphill, you should shift to 6th icon_rolleyes.gif.
Translated on 29-09-2026, 6:18.
slg60
Post21-01-2011, 20:40    Subject: Quote
Yes, new MSTG! I saw it myself!
Translated on 29-09-2026, 6:19.
No new posts VCDS: HEX-USB CAN adapter not found after update General Tips
No new posts Engine Control Unit Errors: 2.5L V6 TDI (No Delete) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Software updates for Engine Control Unit, Assessment and ... General Tips
No new posts 2.8L V6 AAH - No communication On-Board Diagnostics (OBD)
No new posts Skoda Octavia: No Radio Communication? On-Board Diagnostics (OBD)
No new posts ACC/PDC Failure: No Communication - Troubleshooting Electrical Systems, Vehicle Electronics, Multimedia
No new posts Passat 3b5 keine Kommunikation ABS-Schalttafeleinsatz On-Board Diagnostics (OBD)
