Schweiger wrote: |
Since I didn't receive even the smallest hint from this forum, I did my own research and found a solution: After resetting the entire electronics (there's a process for that), everything worked again; the slipping is gone.
Thank you again for the detailed feedback.
Greetings from the edge of the Ruhr area.
J. |
Good day.
ich suche gerade nach Ursachen meines Problems mit der Automatikgetriebe. Your problem.
It's similar to what I have.
Where can I reset all the electronics?
I will check the engine specifications later on the Audi's documentation.
Thomas.
