Oil Temperature: How to Check & Optimize
Steffi H.
Post31-05-2002, 8:24    Subject: Oil Temperature: How to Check & Optimize Quote
I have one or two questions for everyone who has a performance chip installed. What is the oil temperature like for you? Mine reaches around 120-130°C with spirited driving at speeds of 160-170 km/h.
According to my mechanic, this shouldn't be a problem. My friend thinks that an oil cooler would be a worthwhile addition.
How hot can the oil get during a prolonged drive under full load?
That's all my questions for now, and I'm looking forward to your answers.
Best regards, Steffi H.
Translated on 21-08-2026, 7:40.
Martin L.
Post31-05-2002, 11:03    Subject: Oil Temperature: How to Check & Optimize Quote
'120 to 130° is probably definitely too high. I drive a Golf III AAZ TD with an aftermarket intercooler. I'm also about to install an oil cooler. While 160-170 [horsepower] is quite fast, it's still not in the upper range of the stock power output.'
Exceeding an oil temperature of 120° significantly degrades the quality of the oil and should be avoided. To my knowledge, even Schumacher operates his engine at oil temperatures around 80°. His engine is likely operating right at its thermal limits.
Translated on 21-08-2026, 7:42.
Thomas K.
Post03-06-2002, 12:11    Subject: Oil Temp: Up to 150°C is OK (VW) Quote
Oil temperatures of 120-130°C under prolonged full throttle are not a problem and there is no need to install an additional oil cooler. Volkswagen allows up to 150°C with the appropriate oil that meets Volkswagen standards.
In meinem alten 1er GTI hatte ich trotz Ölkühler manchmal Öltemp. von bis zu 145°. Immer Vollsynthetiköl gefahren. Auto mit 240tkm verkauft. Kein Oil consumption.
So, no need to worry.
Translated on 21-08-2026, 7:43.
Michael II
Post03-06-2002, 12:58    Subject: Oil Temperature: How to Check & Optimize Quote
Hello Thomas,
What kind of engine was that?
Tschüss
Michael II
Translated on 21-08-2026, 7:44.
Steffi H.
Post03-06-2002, 18:17    Subject: Oil Temperature: How to Check & Optimize Quote
Hello everyone,
'So, I recently had my car inspected. Apparently, the workshop foreman took my comment about the high oil temperature seriously and switched to fully synthetic oil; and sure enough, now the temperature doesn't even exceed 120°C.'
If things continue like this, I might actually be completely satisfied with it.
Steffi H.
Translated on 21-08-2026, 7:45.
Thomas K.
Post03-06-2002, 19:45    Subject: Pirelli GTI: Michael II - A Classic Car Story Quote
Hello Michael,
My dearly loved Golf GTI was one of the last models of that series; it was a Pirelli GTI with a 1.8L engine and 112 horsepower, engine code 'DX'. It had been slightly tuned (throttle body and cold start valve from an Audi 5E, 276° camshaft, exhaust manifold, Gillet exhaust). It probably produced around 135 horsepower. I still regret selling it today.
'I currently drive a Volkswagen Golf IV TDI with a 115 horsepower engine and a PSI tuning module.'
Thomas.
Translated on 21-08-2026, 7:46.
No new posts Oil Temperature Gauge: Add-on Instrument Diesel Engine Technology
No new posts Oil Temperature: Where to Measure It? Diesel Engine Technology
No new posts Oil temperature sensor Diesel Engine Technology
No new posts What oil temperature is too high for the cylinder head ga... Diesel Engine Technology
