Passat / Superb: Interior to Engine Compartment Installation
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
Georg_G
2012 Volkswagen Golf
Post13-02-2011, 17:36    Subject: Passat / Superb: Interior to Engine Compartment Installation Quote
I'm referring to a Superb I, Mj. 2008, which is largely identical to the Passat 3BG.
I'm looking for a way to run a thin hose from the interior to the engine bay for my boost gauge. I've already removed the trim panel below the steering wheel. However, after a long search, I haven't found any blind plugs or similar.
There must be a way to get to the engine control unit from the cable tree, right? But it's so tightly packed in there, there must be a simpler solution!
Does anyone have a tip for me?
Regards, Georg
voodoo
Georg_G likes this.
Post14-02-2011, 10:44    Subject: Passat / Superb: Interior to Engine Compartment Installation Quote
From the control station (where the MSG is located), it is possible to access through the existing cable runs through the splash guard.
One needs to go below the electrical panel.
Best regards, Stefan
scrdel
Karma: +4 / -2   Thank you, like it!
2002 Volkswagen Passat
Post14-02-2011, 20:52    Subject: Passat / Superb: Interior to Engine Compartment Installation Quote
Hello, or just remove the carpet under the pedals, then you can also go through the splash guard.
Sven
Georg_G
Post15-02-2011, 10:16    Subject: Passat / Superb: Interior to Engine Compartment Installation Quote
Voodoo, thank you for the response.
I had hoped there might be another way, but I suppose I have to do it this way.
scrdel, Unfortunately, I couldn't find a blind stopper under the rug.
Greetings, Georg
scrdel
Post15-02-2011, 21:09    Subject: Passat / Superb: Interior to Engine Compartment Installation Quote
Hi, yes, there is indeed a way, at least for me, because I have installed the wiring for my space heater. It is located near the area where I don't have a clutch pedal. Take a look here:
/viewtopic.php?t=20126
I once wrote something down there, where you can see where the wires come out from the foot area and where they go in from the motor side.....
Best regards, Sven.
Georg_G
Post18-02-2011, 22:48    Subject: Passat / Superb: Interior to Engine Compartment Installation Quote
Again, feedback:
The cable entries in the footwell also exist, as described by scrdel.
However, the implementation by the motor control unit housing is significantly better, as it allows for the routing of a charging pressure hose through the water tank.
Small tip: The (when looking at the car from the front) last screw of the plastic cover of the MSG box under the defogger can be loosened from above by removing a plug in the defogger.
This fitting is extremely difficult to see, simply very well fitted icon_smile.gif
We need a 1/4" 8mm socket with a extension. 3/8" is already too thick for the hole in the wind deflector.
Thank you for your feedback,
Georg
No new posts Passat 3C oder Superb 3T Notentriegelung Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Exhaust fumes inside the cabin, VW T6 TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Dry the interior General Tips
No new posts Durchgang Motorraum / Innenraum Golf 4 Diesel Engine Technology
No new posts Tip: Dampy interior, Passat 3B Transmission, Chassis, Body & Interior
No new posts Exhaust fumes inside the car Transmission, Chassis, Body & Interior
No new posts Kleber für Kunststoffteile Innenraum Transmission, Chassis, Body & Interior
