Turboladerlebensdauer bei TDIs | Posts 48+
Go to page: Previous  1, 2, 3, 4
Nach welcher Laufleistung trat bei Eurem TDI der erste Turboladerschaden auf?
weniger als 50.000km
10%
 10%  [ 9 ]
zwischen 50.000km und 100.000km
18%
 18%  [ 15 ]
zwischen 100.000km und 150.000km
9%
 9%  [ 8 ]
zwischen 150.000km und 200.000km
15%
 15%  [ 13 ]
zwischen 200.000km und 250.000km
6%
 6%  [ 5 ]
mehr als 250.000km
39%
 39%  [ 33 ]
Total votes : 83
Hati
Post11-01-2005, 22:20    Subject: Quote
The VTG is stiff or not movable to the lower end. This occurred at a mileage of 94,000 km. Then, after 650 km of continuous use on the highway (holiday return journey), it was functioning normally for 3 months. Now, at approximately 102,000 km, the turbocharger needs to be replaced at VAG. (At least, the car was handed over to VAG today with this repair order), after the turbocharger failed to build up sufficient pressure during the diagnostic process.
Driving Profile: For the first 94,000 km, I can only say: USED AS A DRIVING SCHOOL CAR
Since then, it has been operating in a mixed mode for 9,000 km. 75% on highways; 15% on country roads; 10% in urban areas.
gwg
Post11-01-2005, 22:39    Subject: Quote
On my ARL engine, the ATL failed one day and approximately 100 km after the oil change with a 50,000 km service.
A rascal, who is thinking of doing something evil.
It was still 'warranty'.
Günther
Klemmi
Post12-01-2005, 18:15    Subject: Quote
I have an A6 C4, current mileage around 230,000 km, 1st turbocharger, I've often had problems with the timing belt, MKB AEL, chipped by Nothelle in Mülheim, around 160 hp. However, I've always been lucky and haven't had any engine damage, my wife has good hearing (noise from the water pump, etc.). The oil consumption is 1.0 liter per 15,000 km, approximately 35% city, the rest on the highway. I've never really floored it, but I've always maintained very good average speeds. I'm very satisfied and let's see how long the engine lasts. The fuel consumption is around 7 liters of diesel.
golf 3 pd tdi
Post16-01-2005, 23:09    Subject: Quote
Hallo, I'm driving an ASZ with a 6-speed gearbox. I've been driving it for 30,000 km. Now it has 45,000 km. It was chipped at 31,000 km. At 40,000 km, the shaft in the turbocharger broke. Cause: defective VVT regulator solenoid... icon_cry.gif
Kombifahrer
Post17-01-2005, 11:19    Subject: Quote
175,000 km, then turbo failure.
I have a Passat with AVG / 81 kW + PSI box, approximately 25 PS (from the beginning).
Primarily driving in urban areas with a car trailer (approximately 2 tons).
Best regards, Thomas
PeterAFN
Post19-02-2005, 22:58    Subject: Quote
drive a Passat with AFN
Turbocharger failure at 360,000 km (yesterday)
Driving Operation:
15% of the city
55% Road
30% BABY
Consumption: 6.5 to 7 l/100km
Greetings
Peter
pax
Avatar-pax
2000 Volkswagen Passat
Post10-02-2006, 19:25    Subject: Quote
Passat 3B, Engine Code: ATJ
"Turbocharger exchange at 184,000 km, Fault diagnosis: excessive turbocharger pressure, the exact fault is unknown as the workshop has retained the faulty turbocharger.
Driving Profile: Since [NUMBER] km - Current mileage: approximately 137,000 km. Approximately 50% on country roads (approximately 5 liters/100km), 50% in the city (6.5 liters/100km). I don't know exactly what was done to the vehicle before (a well-maintained company vehicle, owned by a previous owner).
Bye
pax
bastion
Karma: +6 / -1   Thank you, like it!
Post11-02-2006, 1:46    Subject: Quote
Audi A4 AHU
Defect at approximately 100,000 km. Faulty control box, resulting in excessive speed and subsequent rotor failure in the exhaust duct.
At that time, it was mostly urban and rural roads. Occasionally, I also ride long distances >1000km.
olkoo
Post11-02-2006, 7:58    Subject: Quote
Hello
My experiences:
Previous D
400,000 Km A100 5 Cyl. = 1 Ton with 1 Turbo (200,000 km with tuning)
400,000 Km A100 5 Cyl. = AAT with 1 Turbo (100,000 km with tuning)
320,000 Km A6 5-cylinder = AEL with 1. Charger (320Tkm with tuning)
340,000 Km A100 5-cylinder = NC with 1.L charger
180,000 Km Go3 4-cylinder = AAZ with 1 turbocharger (90,000 Km with tuning)
Previous B
300,000 Km A200 5-cylinder = 3B with 1 turbocharger (100,000 km with tuning)
240,000 Km A200 5-cylinder = 3B with 2-stage turbo (15,000 km with tuning) 1. Lader had high oil consumption.
280.000Km S4 5Zyl. = AAN with 1. Charger (40Tkm with tuning)
currently (my 1. VTG)
165,000 Km, Pass3BG, 4 Cyl. = AVF with 1. Charger (2Tkm with tuning)
Km figures = approximate figures
hello
Olli
Uwe
Post11-02-2006, 8:48    Subject: Quote
Wow, did you drive all those miles yourself?
Kundenservice bedeutet bei Audi, die Kunden so schnell über den Tisch zu ziehen, daß sie die Reibungswärme als Nestwärme empfinden!
Boro
Post13-02-2006, 8:10    Subject: Quote
Ibiza Tdi AFN
273400 km
First load, no problems.
olkoo
Post13-02-2006, 14:27    Subject: Quote
@UweViewing profile: Uwe
Average mileage was around 70-100,000 km per vehicle.
Besides AAZ, who belonged to my wife.
olli
darkcali
Post19-02-2011, 10:36    Subject: Quote
Then I also want to:
audi a4 tdi AFN 300tkm charger completely ok and full boost pressure consumption: 6-8 liters
audi a3 tdi ALH 270tkm, charger ok
verbrauch: 5,2-7liter
golf 4 PD 130ps, turbo ok, 200tkm
audi a6 2.5tdi, build 320tkm, first turbocharger, but now making some noises (80%BAB), consumption: no idea, father-in-law, but drives more gently.
We have been driving these three Audis for many years and they all have the original turbocharger.
city: 20%
land: 40%
BAB: 40%
Ride Profile: Always ride warm and cold, otherwise full throttle.
No new posts Used car inspection tips for TDIs Technical Articles
No new posts Repair of oil pump drive for 2.0 PD TDIs with balance shafts Troubleshooting & Guides
No new posts Forced DPF Regeneration: VAG TDI with VCDS Troubleshooting & Guides
No new posts TDIs dry driving? Diesel Engine Technology
No new posts TDI Overview: Features & Benefits Diesel Engine Technology
No new posts Abgasrückführventil, diverse 2.0l TDIs Diesel Engine Technology
No new posts Schwächen aktuelle 3.0l V6 TDIs Diesel Engine Technology
