Check ZK for Leaks and Cracks
pa-mm6
Karma: +1 / -1   Thank you, like it!
Post26-02-2011, 13:29    Subject: Check ZK for Leaks and Cracks Quote
"For a few weeks now, my A4 170 HP TDI (German market) hasn't always started immediately. The temperatures are quite cold for this time of year, ranging from -15 to +3 degrees Celsius. Sometimes, after the glow plugs have warmed up, it suddenly cranks for 4-5 revolutions before it finally starts. When it's warm, it starts immediately..."
The current mileage is 89,000 km. At 80,000 km, the PD elements were cleaned, and according to the mechanic, the timing chain cover was also inspected for cracks, as this can sometimes occur in this model. There were no cracks found at that time, according to the mechanic; everything was in perfect order.
The coolant level remains the same. There is no water in the engine oil. The defective glow plugs are also not displayed in the diagnostic system, and there are no other error messages.
I have a strange feeling, especially since the warranty expired this year. But normally, Audi will often cover the cost of a faulty thermostat on good will basis, even if the mileage is under 100,000 km.
There might be other methods to check the tightness or cracks in the ZK (presumably referring to a specific component or system).
Thank you for your suggestions...
Audi SQ5 8R Cvub
Translated on 13-10-2026, 13:09.
Back to top Profile PM Email
BM
Avatar-BM
Post26-02-2011, 16:42    Subject: Check ZK for Leaks and Cracks Quote
Perhaps there are other methods to check the ZK for tightness or cracks...
Disassemble and x-ray icon_wink.gif.
To be honest, I don't see any reason to look for cracks when it's highly unlikely that there are any.
And as for why it doesn't always start on the first turn, there are a thousand other possibilities. As long as it starts reasonably well, which it does, I don't see any reason to investigate this further.
PS: Your homepage, tdidealer.dyndns.tv, is hindering the page loading process.
3B5 AJM
Translated on 13-10-2026, 13:11.
pa-mm6
Post26-02-2011, 19:06    Subject: Check ZK for Leaks and Cracks Quote
"Sorry, but I'm just worried because he usually starts right up on the first turn, which is typical for TDI engines. You usually don't read much good about the engine, although so far I haven't had any problems with it, except for the carbonized injectors."
I'm just a little skeptical because it no longer has a warranty. If there's an issue with the engine, Audi usually only offers goodwill coverage up to 100,000 km. Anything above that is usually denied.
"MFG" is an abbreviation for "mit freundlichen Grüßen," which means "best regards" or "sincerely." It is commonly used in German-language emails and letters.
Audi SQ5 8R Cvub
Translated on 13-10-2026, 13:12.
No new posts Air leak in turbocharger pressure line, AFN engine Diesel Engine Technology
No new posts Turbo Leak Repair: VW Golf 3 (1Z) Diesel Engine Technology
No new posts Cracked Cylinder Head Tdi Diesel Engine Technology
No new posts Cracks in New Tires: Causes & Solutions Transmission, Chassis, Body & Interior
