DPF lose Teile | Posts 16+
Go to page: Previous  1, 2
Post26-02-2011, 10:56    Subject: Quote
=> It's going to get interesting when the DPF systems start getting old!
I'm afraid so too... Weasel damage to the charge air duct would likely lead to a constantly full DPF (diesel particulate filter), even without a clearly noticeable loss of performance.
"Normal" air mass values at intake pressure x and fuel injection amount y under standard conditions z would be useful as comparison parameters. I will start logging and archiving such data for my own reference.
Translated on 06-08-2026, 17:19.
Deus Violentia
Post26-02-2011, 11:49    Subject: Quote
Either the dealers will make a fortune, or Volkswagen will get fed up and start offering dummy housings and corresponding software updates for the control units themselves. icon_cool.gif
BKD GRF
AHF EBF
Translated on 06-08-2026, 17:20.
teileklaus
Avatar-teileklaus
Karma: +12 / -0   Thank you, like it!
2005 Volkswagen
Post27-02-2011, 13:26    Subject: Quote
Danke für die Erklärungen, es werden wohl auf dem Austauschmarkt einige auf den Plan rücken, die Originale wieder mit ihrem Innenleben aufrüsten. OdeBrand new.
I spoke with two people who are focusing on this. Apparently, production is already starting up. So far, I only see suppliers in France and the Netherlands, but I don't want to place orders with them.
I had also considered cutting the DPF at the weld seam, mechanically securing the filter blocks in place with stainless steel wires, and continuing to drive like that until cheaper replacement parts become available.
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Translated on 06-08-2026, 17:21.
vagtuning
Post27-02-2011, 13:46    Subject: Quote
The error is not uncommon - it was fixed in 2009 with a modified approach.
Adhesive bonding processes within the diesel particulate filter (DPF) during mass production.
Usually, these errors are accompanied by codes such as 05213, 08194, or 00665.
The DPF (Diesel Particulate Filter) needs to be replaced, and possibly the exhaust temperature sensor as well.
Translated on 06-08-2026, 17:22.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post27-02-2011, 15:26    Subject: Quote
Okay, so it seems like the durability issue is related to a manufacturing problem.
Thank you for the clarification.
Translated on 06-08-2026, 17:23.
BM
Avatar-BM
Post27-02-2011, 22:32    Subject: Quote
aha vagtuning, so it's actually a durability problem with the manufacturing process.
You're right -- Matchbox. À la carte.
3B5 AJM
No new posts Golf 1J documentation up to 05/99, loose license plate light Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Sharan, Servicedeckel Heckklappe lose Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Dodge Sharan 7M, Loose Side Bumper Cover Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Loose Air Intake Hose: What are the Effects? Diesel Engine Technology
No new posts Injector bridge suddenly loose - how is that possible? Diesel Engine Technology
No new posts ESD for 1Z and part number 028 130 201 HX. Is it compatib... Diesel Engine Technology
No new posts Defective PD Elements: Loose Spring & Piston Diesel Engine Technology
