6 Gang Getriebe, warum so kurz übersetzt? | Posts 16+
Go to page: Previous  1, 2
Post03-03-2011, 8:43    Subject: Quote
Not the same.
I could potentially source a 5-speed manual BLS Passat Bluemotion.
BLS = 1.9 mPD DPF 105 hp 250 Nm
BMR = 2.0, 16V, PPD, 170 hp, 350 Nm.
JYJ = at 6. Gang extended MQ250.
JMA = 6-speed MQ350 transmission for the wagon (the sedan has a slightly longer gear ratio).
Karma: +1092 / -0   Thank you, like it!
Post03-03-2011, 9:10    Subject: Quote
Oops, I'm not very familiar with MKB and GKB when it comes to your vehicles. icon_rolleyes.gif Is the sedan geared longer than the wagon?
Why?! Do they differ significantly in weight/wind resistance?
I can note the following for my marble: MKB: 8HZ and GKB: MA/5.CXL.
Post03-03-2011, 9:23    Subject: Quote
Is the limousine longer than the station wagon?
It was the same with the Golf 3. He also used other combinations of bicycle tires and rims.
The station wagon will most likely be used more as a workhorse for hauling cargo. The 3C, when registered as a combination vehicle, is also officially recorded as being 3 km/h slower.
The speedometer reads 167 km/h at 3000 rpm, which is enough for me, but it's a bit long icon_smile.gif.
No new posts Document: Gear Noise, 6-Speed Transmission Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Documented noises from the dual-clutch transmission, 6-sp... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Gearbox 02K: 3rd Gear Hard to Shift Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Upgrade 5-speed to 6-speed gearbox VW G3 AHU Diesel Engine Technology
No new posts Golf 5 1.9 TDI 5-speed 6-speed gearbox ZMS clutch Diesel Engine Technology
No new posts 6-Speed Transmission Upgrade for G4 ALH Diesel Engine Technology
No new posts PD 6-speed transmission on an AFN? Diesel Engine Technology
