Smart Oil Level Sensors: Benefits & Uses
Wiesel
Post01-03-2011, 12:45    Subject: Smart Oil Level Sensors: Benefits & Uses Quote
since it appears that the service interval was not reset during the last service.
I then fulfilled the service request for our Polo on Saturday with a friendly reset.
answered.
When my better half left yesterday morning, the AI system grumbled, "Check the oil level" icon_eek.gif.
Result of the inspection: The oil level was still within the marker, but at the lower end.
0.5 liters added -> AI is happy.
Does the AI actually consider the mileage since the last oil change when providing an oil level warning?
"After a service reset, one might expect the engine to be ideally filled with oil, or is that a 'safety feature'?"
so that it becomes obvious during the test drive that the oil change was forgotten?
Micha
Translated on 29-09-2026, 4:54.
mserge
Post01-03-2011, 16:11    Subject: Smart Oil Level Sensors: Benefits & Uses Quote
My AI system is already warning me about the oil level being at the minimum, but I find that okay, as it gives you time to refill. I don't think the system is that "intelligent" and knows that you've changed the oil.
neuer Turbo bei 200.000km
neue ESP bei 216.000km
verkauft mit 225000tkm
Clio 2 RS 170 PS BJ2003
Translated on 29-09-2026, 4:56.
Wiesel
Post01-03-2011, 17:51    Subject: Smart Oil Level Sensors: Benefits & Uses Quote
Hmm...
The last time he checked the oil level, he added one liter to bring it back up.
Micha
Deus Violentia
Post01-03-2011, 19:41    Subject: Smart Oil Level Sensors: Benefits & Uses Quote
I suspect the sensor isn't evaluated constantly, but periodically, perhaps during service or immediately after a service reset. Why do you let it get to the point where so much oil is missing? You could simply get into the habit of checking it, for example, while you're refueling.
BKD GRF
AHF EBF
Translated on 29-09-2026, 4:57.
Wiesel
Post01-03-2011, 19:50    Subject: Smart Oil Level Sensors: Benefits & Uses Quote
My Volvo 740 didn't have any of those fancy features.
It was always happening at the wrong time, when the oil pressure warning light came on in curves icon_twisted.gif.
Post01-03-2011, 20:01    Subject: Smart Oil Level Sensors: Benefits & Uses Quote
PS: As soon as the hood was opened, the message in the instrument cluster disappeared, as it assumes that the oil level has been topped up. As far as I know, the oil level is detected using a dipstick with different heating sections. The cooling curve is used as feedback.
Translated on 29-09-2026, 4:58.
Deus Violentia
Post01-03-2011, 20:07    Subject: Smart Oil Level Sensors: Benefits & Uses Quote
@ Matthias: Very good, THANK YOU!
BKD GRF
AHF EBF
Wiesel
Post01-03-2011, 21:24    Subject: Smart Oil Level Sensors: Benefits & Uses Quote
Hi Matthias,
Thank you for the hint...
I have here: http://www.t4-wiki.de/wiki/Geber_G266_%28%C3%96lstand/%C3%96ltemperatur%29
I found a pretty good description.
Micha
Translated on 29-09-2026, 4:59.
michiglaser
2007 Audi A4 Avant
Post02-03-2011, 1:55    Subject: Smart Oil Level Sensors: Benefits & Uses Quote
matthiasTDI96 wrote:
P.S.: Once the hood was opened, the message in the instrument cluster disappeared, as it assumes that it was due to a refill.
It's worth mentioning that in some vehicles, the warning message on the instrument cluster may not disappear even after topping up the oil, because the hood contact sensor is dirty or corroded.
"This is something that occasionally happens with the T4."
T5 California (CFCA) 4Motion
A4 B8 Avant (CDUC)
G4 (ASZ), T4 (AXG)
Devilseye503
Post03-03-2011, 18:11    Subject: Smart Oil Level Sensors: Benefits & Uses Quote
It's also possible that the following factors played a role: the engine was warm in the evening and cold in the morning (1. sensor issues and 2. volume reduction due to cooling).
With DAF trucks, for example, the oil level can only be read once the engine has reached its operating temperature and has been stationary for 15 minutes. This is supposedly intended to provide a more accurate oil level check... However, no one mentions the fact that very few people actually have the time to wait that long for the check.
Translated on 29-09-2026, 5:01.
No new posts Document A2 8Z0 MJ 2002, The radio displays "Transport" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts "Rain Shield" by No Touch: Practical Test General Tips
No new posts Resolution: "Crack in BKD cylinder head" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat Engine Codes AVF & EYF - Parts & Info Diesel Engine Technology
No new posts Euro 4 requirement not as "absolute" as previously thought? Diesel Engine Technology
No new posts Injector Nozzles: Can You Repair the "Tips"? Diesel Engine Technology
No new posts RNS315 Upgrade: Install "Discover Media" Now! Electrical Systems, Vehicle Electronics, Multimedia
