Headlights Golf 3: Buy & Install
Kusi
Karma: +8 / -1   Thank you, like it!
Post01-06-2002, 19:08    Subject: Headlights Golf 3: Buy & Install Quote
Hello.
This afternoon, I installed the dual headlights from a GT model into my Golf III TDI. Unfortunately, they aren't working the way I want them to. Specifically, I want the low beam headlights to remain on when I turn on the high beams.
At some point, I read that if something doesn't work, I need to install a "bridge" somewhere. Unfortunately, I can't find the source anymore. Where exactly do I need to install this "bridge," and where can I even get one? Will a standard fuse handle it?
Questions upon questions.
I would be very grateful if someone could provide me with some information.
A sunny greeting.
Kusi.
Translated on 22-09-2026, 0:34.
Varianti
Post03-06-2002, 10:06    Subject: Headlights Golf 3: Buy & Install Quote
'Ask Hella. They have an installation guide for their clear headlights. It may be necessary to install a bracket, and Hella also supplies those brackets.'
Translated on 22-09-2026, 0:35.
AMB1980
Post03-06-2002, 11:28    Subject: Headlights Golf 3: Buy & Install Quote
The thing about the bridge is true, but I also installed the GT headlights, and the TÜV (German technical inspection authority) doesn't complain if the bridge is missing icon_lol.gif.
Kusi
Post03-06-2002, 21:13    Subject: Bridge: Definition, Types, and Examples Quote
Hello AMB1980,
The TÜV (German technical inspection agency) isn't my problem either; I simply want it to be bright in front of my car when using high beams. However, that only works if the bridge is present, which means both the high beams and the low beams are on.
Kusi.
Translated on 22-09-2026, 0:36.
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf IV 1.9 TDI AXR - Stutters under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 5 1.4 BUD Misfire 2. Cylinder Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Tacho Golf 3 an 6-GangGetriebe aus Golf 4-> kein Signal ? Diesel Engine Technology
No new posts Golf 2 GTD/16V: Brake Caliper & Wheel Bearing Mount Transmission, Chassis, Body & Interior
This topic is locked, you cannot edit or reply. Golf 3 TDI: Install 6-Speed Golf 4 Transmission Diesel Engine Technology
No new posts Golf 3 Instrument Cluster in Golf 2 Dashboard Transmission, Chassis, Body & Interior
