Leon Bj05: Weak Brakes (Fixed?)
pit von DO
Post24-03-2011, 10:08    Subject: Leon Bj05: Weak Brakes (Fixed?) Quote
Hey guys,
So, here's what I did:
- Timing belt replaced.
- Take it out of gear.
- ZMS (torque converter) and clutch replaced.
- Reinstall the transmission software.
- Front brake discs and pads replaced.
Current status:
- The engine, transmission, and clutch are in good condition.
- The brake pedal is hard, but the braking performance tends towards zero.
Done.
- Brake bled with a bleeder.
- Run the ABS pump for at least 10 seconds.
My VAG-Com is an old 409.1 US version.
I bought the adapter a long time ago as a used "Ross part".
I have absolutely no idea whether this is the original or not... icon_question.gif
I probably don't have an ABS bleed function (yet).
Regarding the symptom again:
- It feels like the power brake assist has failed...
Just to be aware that in the event of a brake booster failure, significantly more braking power will be available!
Axo, I just remembered something:
- I had an error message, which I unfortunately didn't save. icon_redface.gif
"Brake pedal signal not plausible."
pit
Translated on 26-10-2026, 9:36.
Post24-03-2011, 11:19    Subject: Leon Bj05: Weak Brakes (Fixed?) Quote
The ABS bleeding process for your vehicle is performed through the actuator diagnosis function, which requires a licensed VCDS/VAG-COM software.
Is your brake pedal spongy (= brake system not properly bled or leaking), or do you have a hard pedal feel but very weak braking performance (brake booster not receiving vacuum or faulty brake booster)?
Translated on 26-10-2026, 9:39.
pit von DO
Post24-03-2011, 11:20    Subject: Leon Bj05: Weak Brakes (Fixed?) Quote
pit
RedR32
Avatar-RedR32
1998 Volkswagen Golf
Post24-03-2011, 11:30    Subject: Leon Bj05: Weak Brakes (Fixed?) Quote
Unfortunately, you've run the fluid reservoir dry, and now there's air in the control unit's valve block. This has happened to me before too.
Just so that in the event of a brake booster failure, significantly more braking power is available
Don't be mistaken.
There are two ways to fix this: Either solution A, which is what Rainer suggested (and would be beneficial for a car of your age anyway), or...
You can either go to a Seat dealership and have them perform a guided actuator diagnosis for brake bleeding. The cost is approximately €50-100 for about half an hour of work. That's my experience.
/viewtopic.php?t=22474
reflexsilber met.
Translated on 26-10-2026, 9:40.
pit von DO
Post24-03-2011, 12:19    Subject: Leon Bj05: Weak Brakes (Fixed?) Quote
Men,
Thank you both!
Yes, Rainer, then I probably have to become a customer in the new month... icon_smile.gif
I've read it and understood it!
But I have a small update from the front lines!
I have one wrongdoer.
After a bit of wobbling and twisting of the "Nipfie," a hissing sound could be heard.
@rainerViewing profile: rainer
The resistance from the pedals was immediately very stiff, with very little give.
...now it's softer and the braking force has increased!
I'm going to replace that part right away. Then we'll see how it goes.
Why do such errors always occur after completely different kinds of tinkering? icon_twisted.gif
pit
Translated on 26-10-2026, 9:42.
Post24-03-2011, 12:55    Subject: Leon Bj05: Weak Brakes (Fixed?) Quote
pit von DO wrote:
Why do such errors always occur after completely different kinds of tinkering?icon_twisted.gif
Because it involves moving all sorts of (potentially fragile) hoses...
Translated on 26-10-2026, 9:44.
pit von DO
Post25-03-2011, 8:58    Subject: Leon Bj05: Weak Brakes (Fixed?) Quote
Okay, the initial problem has been resolved!
I have to hold myself accountable and admit that I made a mistake... icon_confused.gif
When removing the transmission, the engine needs to be lowered on the transmission side.
Sure, we know that. And we have to remove all the hoses and cables that could get in the way.
disconnect, or remove from the way.
I overlooked the vacuum hose that connects the tandem pump to the brake booster.
It detached on its own. In the process, the rubber bushing in the BKV (hydraulic control unit) tore! icon_eek.gif
That was the main problem!
Okay, the car is braking very nicely again! I'm going to take it to the TÜV (technical inspection) as it is, and then we'll see.
continue.
I encountered the same error message on my last trip, even though the BKV (presumably a system or device) was malfunctioning.
"Received an implausible brake pedal signal," but I'm still investigating the cause.
Follow-up errors, and I'll ignore it for now.
Thanks again for the tips!
@Rainer - I'll get in touch with you regarding the next payment after that one! icon_smile.gif
pit
Translated on 26-10-2026, 9:45.
No new posts Fix Error 00777: Strange Effect? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Seat Leon, 2012 model, LED brake light flickering Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Turbocharger Problems: 1Z Engine Issues On-Board Diagnostics (OBD)
No new posts Rail pump, Opel Astra, likely faulty Diesel Engine Technology
This topic is locked, you cannot edit or reply. A6 TDI ESP Fault: 2.5L, 110kW, 1998 Diesel Engine Technology
No new posts Audi A6 2.5 TDI 110kW - No power and poor shifting On-Board Diagnostics (OBD)
