Automatic Transmission Not Shifting? Fix It!
menzinger68
Post06-04-2011, 14:13    Subject: Automatic Transmission Not Shifting? Fix It! Quote
Due to an electronic malfunction caused by oil on the connectors at the multi-function switch and other components, the emergency program has been activated in the transmission. I drove approximately 100 km in this emergency mode without noticing any significant issues.
I cleaned the connections with brake cleaner, without opening them.
Today, I tried clearing the error codes in the transmission's memory. The emergency program is also active.
BUT:
It's not shifting anymore. It's stuck in first gear. It doesn't work with the Tiptronic either. I drove around for a few more blocks and then read the error codes, but there are no entries.
How should I proceed?
Thomas.
Audi A4 Avant, 2,5 TDI V6 , BJ 1999, Motor AFN
Getriebe DAJ DEY
Translated on 30-09-2026, 20:29.
vwSchrauber
Post07-04-2011, 11:16    Subject: Automatic Transmission Not Shifting? Fix It! Quote
Is the engine control unit (ECU) properly coded?
Does the transmission control unit display the position of the gear selector, specifically whether it's in "D" or another position?
Translated on 30-09-2026, 20:30.
menzinger68
Post07-04-2011, 11:30    Subject: Automatic Transmission Not Shifting? Fix It! Quote
I can't tell if the encoding is correct. Where can I check?
The diagnostic software indicates that gang 1 has been created.
But I'm wondering why no new errors are being written to memory when I've deleted the old ones.
Does anyone know quickly how I can reactivate the emergency program?
Thomas.
Getriebe DAJ DEY
Translated on 30-09-2026, 20:31.
vwSchrauber
Post07-04-2011, 12:52    Subject: Automatic Transmission Not Shifting? Fix It! Quote
I can't determine whether the encoding is correct. Where can I look?
In the engine control unit. VCDS provides direct assistance during coding; simply hover your mouse cursor over the relevant field for help.
The diagnostic software says that gang 1 has been created.
You need to distinguish between the position of the gear selector and the actual gear that is engaged.
Do you also have the display in the instrument cluster that shows the selector lever position? Does it remain in first gear when you shift through the different selector lever positions?
It's possible that your position sensor is malfunctioning and sending a signal to the transmission control unit (TCU) indicating that first gear is selected. In this case, the TCU will prevent shifting to higher gears because it believes that you have locked out the higher gears (e.g., for driving uphill).
Translated on 30-09-2026, 20:32.
menzinger
Post07-04-2011, 13:03    Subject: Automatic Transmission Not Shifting? Fix It! Quote
I only see the indicator for the gear selector position on the display next to the speedometer when it's in P, R, or N.
If I set it to "D", the indicator disappears. However, the letters and numbers are still visible, just without the bar behind them.
When switching to Tiptronic mode, "1" is highlighted. The manual upshift function does not work.
Im Diagnosesoftware sehe ich den 1. Gang installed.
Thomas.
Translated on 30-09-2026, 20:36.
No new posts Smart Fortwo: Gear won't shift from Neutral to Drive General Tips
No new posts A2 Radio: Won't Turn On After Parking? (8Z0) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 Radio Problem: Fix for 8L Models Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A6 2.5 TDI Automatic Transmission Problems (Solved) On-Board Diagnostics (OBD)
No new posts Radio won't turn off? Troubleshooting tips On-Board Diagnostics (OBD)
No new posts The radio won't turn off Electrical Systems, Vehicle Electronics, Multimedia
No new posts Lupo 3L: Won't shift to 5th gear Transmission, Chassis, Body & Interior
