vmann
20-04-2011, 10:05 Subject: Boost Pressure via OBD2 |
I installed a Garmin EcoRoute HD adapter in my Golf 4 Variant TDI (with MKB or ASZ engine). This device allows engine data to be displayed on the Garmin navigation system. The adapter connects to the diagnostic interface and transmits the data to the navigation system via Bluetooth. It is also possible to use a smartphone if the Garmin Mechanic app is installed.
"All the gauges are working except for the intake manifold pressure. In my Vito CDI and my wife's A200 turbo, the intake manifold pressure reading has always matched the boost pressure (compared to a mechanical boost gauge)."
"However, in my TDI, I always see a value of 1.55 bar. This value doesn't change even when the engine speed increases. Is there a particular characteristic of TDI PD engines regarding this?" MB Vito 2,2 CDI
VW Golf IV 1,9 TDI Variant
Translated on 29-09-2026, 18:23.
haithamina Schrauber
Joined: 05/15/2006 Posts: 666 Karma: +27 / -3 Location: 69221 Dossenheim
20-04-2011, 12:02 Subject: Boost Pressure via OBD2 |
I'm not aware of any issues, and the data reading via the OBD interface works both with VCDS and with a digital real-time display, a Scangauge, which I have installed on the steering column (I hope it's okay to mention the company here; otherwise, please remove it).
haithamina 3G5, 110 kW, DFGA, TGV, Variant HL 2018-
Translated on 29-09-2026, 18:25.
Hutfahrer Schrauber
Joined: 10/22/2005 Posts: 7825 Karma: +1099 / -0 Location: BAR
20-04-2011, 12:44 Subject: Boost Pressure via OBD2 |
I also have the Scangauge (permanently installed in the 206), and there was even a review of it by me.  So, why shouldn't it fit?! Automobile Zeitzeugen: |SUZUKI Swift Sport (2008)| |Smart 450 (2002)| |Honda CB 125 F (2018)|
RedR32 Schrauber
Joined: 12/21/2008 Posts: 1071 Karma: +11 / -0 Location: Bad Lobenstein 1998 Volkswagen Golf Premium Support
20-04-2011, 17:58 Subject: Boost Pressure via OBD2 |
"The driver should update his navigation system, and please don't post such low-quality content here anymore." 2010 Caddy kombi life 103 tdisg6 BMM KXW
reflexsilber met.
Translated on 29-09-2026, 18:26.
Profile PM Garage |
vmann
20-04-2011, 19:24 Subject: Boost Pressure via OBD2 |
Thank you for the tip.
It works in other vehicles. MB Vito 2,2 CDI
