Passat 3B AHU springt nicht mehr an | Posts 16+
Go to page: Previous  1, 2
Karma: +1344 / -0   Thank you, like it!
Post30-04-2011, 21:39    Subject: Quote
I only have the data from the 1Z model, but it should actually be compatible with the AHU.
- Axial play of the intermediate shaft: 0.25 mm;
- Tighten the central bolt to 90 Nm + 90°.
To provide counter-pressure, I'm mounting a long, flat piece of metal onto the front gear (using screws in the threaded holes for the vibration damper).
Okay, I understand. Please provide the German text you would like me to translate into English. I will only provide the translation.
This topic is locked, you cannot edit or reply. Pa 3C BMR Won't Start: Error Code 004160 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Engine won't start, Mj 1999 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine won't start, cranks after start attempt Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat, manufactured in 1994, engine 1Z stalls and won't ... On-Board Diagnostics (OBD)
No new posts Passat V6 TDI Won't Start: Error Code 1044 Diesel Engine Technology
No new posts V6 TDI AKN won't start - Troubleshooting Diesel Engine Technology
No new posts Car Won't Start? Troubleshooting Guide On-Board Diagnostics (OBD)
