Here is the complete scan.
Saturday, May 28, 2011, 3:53:42:25614
VCDS Version: DRV 10.6.4
Data as of: 20110418.
Fechi's workshop.
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BĂ€ume, und die BlĂ€tter rascheln leise. Es ist ein wunderschöner Tag, um drauĂen zu sein."
Vehicle type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 56 62 69 72 76 7D
Vehicle Identification Number: VSSZZZ5PZ5R024810
Mileage: 170,990 km
00-Steering angle sensor -- Status: OK 0000
01-Motor electronics -- Status: OK 0000
03-Brake electronics -- Status: OK 0000
08-Climate control/heating unit -- Status: OK 0000
09-Central Electrical System -- Status: Error 0010.
15-Airbag -- Status: OK 0000
16-Wheel steering electronics -- Status: OK 0000
17-Terminal block insert -- Status: OK 0000
19-Diagnosis interface -- Status: OK 0000.
Immobilizer system -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Electric Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Comfort System -- Status: Error 0010.
52-door electric passenger door - Status: OK 0000.
56-Radio -- Status: OK 0000
62- Door, electric, left and right -- Status: OK 0000
69 followers -- Status: OK 0000
72-Door, electric, high, right side -- Status: OK 0000.
76-Parking assist -- Status: OK 0000
7D Auxiliary Heater -- Status: OK 0000
Address 01: Engine Control Module
Label file: DRV\03G-906-016-BKD.lbl
Part number SW: 03G 906 016 FH, HW: 028 101 190 9.
Part: R4 2.0L EDC G000SG 6185
Revision: 12345678 Serial number: SEZ7Z0D2513305
Encoding: 0050072
Operating number: WSC 01286 386 08256
VCID: 6ED7ADE50007
No error codes found.
Readiness: 0 0 0 0 0
Address 03: Brake Electronics
Label file: DRV\1K0-907-379-MK60-F.lbl
Part number: 1K0 907 379 K
Part: ESP FRONT MK60 0103
Encoding: 0023282
Operating number: WSC 06402 785 00200
VCID: 3A7F51B50CCF
Address 08: Climate Control/Heating. Label file: DRV\1K0-907-044.lbl
Part number: 5P0 907 044 C
Component: Climatronic PQ35 004 0202
Operating Number: WSC 00000 000 00000
VCID: 306B739DDAB3
Address 09: Central Electronics
Label file: DRV\3C0-937-049-23-H.lbl
Part number SW: 1K0 937 049 T. Hardware number: 1K0 937 049 T*.
Component: On-board network module SG 1.0 H29 0704.
Revision: 00029000 Serial number: 00000001284598
Encoding: 818A8F2700041000001E00000000000000
VCID: 408B235D6A13
Part number: 5P0 955 119 B
Component: Wiper SE359 012 0402
Encoding: 00056272
Operating number: WSC 00000
2 error codes found:
01064 - Terminal 58d - Interior light dimming.
012 - Electrical fault in the circuit.
00924 - Relay for headlight cleaning system (J39)
009 - Intermittent short circuit to ground.
Address 15: Airbag
Label file: DRV\1K0-909-605.lbl
Part number SW: 1K0 909 605 H, HW: 1K0 909 605 H.
Part: S3 AIRBAG VW8, 023 0700.
Revision: 06023000 Serial Number: 00385D0GVR4L
Encoding: 0021299
VCID: 316D7699D1B9
Address 16: Steering wheel electronics
Label file: DRV\1K0-953-549-MY8.lbl
Part number SW: 1K0 953 549 B, HW: 1K0 953 549 B.
Component: Steering column module 013 0010.
Encoding: 0002042
VCID: 316D7699D1B9
Part number: XXXXXXXXXXX
Component: Steering wheel module 004 0060
Address 17: Control panel module
Label file: DRV\1K0-920-xxx-17.lbl
Part number: 5P0 920 822 E
Component: COMBINATION INSTRUMENT VO3 1056
Encoding: 0000101
Operating number: WSC 73857 133 59851
VCID: 316D7699D1B9
Address 19: Diagnostic interface
Label file: DRV\1K0-907-530.lbl
Part number SW: 1K0 907 530 C, HW: 1K0 907 951.
Component: Gateway H08 0080
Revision: 08 Serial Number: 26001047090020
Encoding: 3D3F4F48078202
VCID: 275998C1EF7D
Address 25: Immobilizer
Label file: DRV\1K0-920-xxx-25.lbl
Part number: 5P0 920 822 E.
Component: IMMO 1056
Operating number: WSC 40418 188 95834.
VCID: 316D7699D1B9
Address 37: Navigation
Label file: DRV\1T0-919-887.lbl
Part number: 5P0 919 887 A
Component: Navigation 0309
Encoding: 0000002
VCID: 408B235D6A13
Address 42: Door electric driver
Label file: DRV\1K0-959-701-MAX1.lbl
Part number: 1T0 959 701 A
Component: Door control unit 09 0139.
Encoding: 0000048
VCID: 3565428925D1
Address 44: Steering Assist
Label file: DRV\1Kx-909-14x-44.clb
Part number: 1K1 909 144 G
Component: EPS_ZFLS, Size 13 1401
VCID: 2F6970E1C78D
Address 46: Comfort System
Label file: DRV\1K0-959-433-MIN.clb
Part number: 1K0 959 433 BL
Component: 01 KSG 0301
Encoding: 98C0009C090905054C4F863000
Operating number: WSC 48585 188 04288
VCID: 7BF194B14375
Part number: 5P0 951 171 A
Component: Interior monitoring 009 4866.
Encoding: 00000000
Part number: 1K0 951 605 A
Component: LIN BACKUP HORN H01 1201
Component: NGS, not mounted.
01135 - Sensors for interior monitoring.
004 - No signal/communication - Intermittent.
00332 - Control for tank lid.
007 - Short circuit to ground.
Address 52: Door electric, passenger side.
Label file: DRV\1K0-959-702-MAX1.lbl
Part number: 1T0 959 702 A
Encoding: 0000048
VCID: 3667458538D7
Address 56: Radio
Label file: DRV\1T0-035-095.lbl
Part number: 1T0 035 095.
Component: Radio 0309
Encoding: 0004403
VCID: EBD124F1B315
Address 62: Door electric, left/right.
Label file: DRV\1K0-959-703-GEN1.lbl
Part number: 1K0 959 703 B
Component: Door control unit 06 0216.
Encoding: 0000016
VCID: 2F6970E1C78D
Address 69: Trailer
Label file: DRV\8P0-907-383.lbl
Part number SW: 8P0 907 383 HW: 8P0 907 383
Component: ANHAENGERELEKTR H01 0010
Encoding: 0000001
VCID: F6E70585F857
Address 72: Door electric strike, right side.
Label file: DRV\1K0-959-704-GEN1.lbl
Part number: 1K0 959 704 B
Encoding: 0000016
VCID: 306B739DDAB3
Address 76: Parking Assist
Label file: DRV\1K0-919-283.lbl
Part number: 5P0 919 283.
Component: 05 Parking Assist System 0101
VCID: F5E50289E551
Address 7D: Auxiliary Heater
Label file: DRV\1K0-963-235.lbl
Part number SW: 1K0 963 235 E, Hardware number: 1K0 963 235 E.
Component: PTC element 0404
Revision: 00800000 Serial number:
VCID: 2D556AE9CD81
End.
I've already been able to narrow down some of the errors, for example:
The error message refers to the interior lighting dimming function (the cigarette lighter illumination is defective).
The relay for the headlight cleaning system has also failed.
I'm afraid I can't make sense of the errors related to the alarm system and the fuel tank flap.
The fuel tank flap closes mechanically, and no changes have been made to the control unit.
In my opinion, the alarm system seems to be working perfectly. gruĂ
Markus
Translated on 05-09-2026, 13:28.
