Hi-Li Door: Sporadic Communication Error 1000
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » On-Board Diagnostics (OBD)
hkss
Avatar-hkss
Karma: +13 / -0   Thank you, like it!
2017 Skoda Yeti
Post16-05-2011, 6:56    Subject: Hi-Li Door: Sporadic Communication Error 1000 Quote
There are occasional errors of this "sporadic" nature appearing here and there in the forum, but I've noticed something here.
"I've cropped out the error messages that appear in my scans and would like to ask a question about them."
"Are there any clues that might be more revealing? Does anyone have any suggestions on where I might be able to find the trigger for this?"
Every 1-2 weeks, I consistently encounter this error during the scan.
Okay, I understand. Please provide the German text you want me to translate into English. I will only provide the translation, without any explanations. I'm ready when you are.
"What does the following excerpt in the scan reveal?"
Time: 0.
Date: 2005.09.13
Time: 31:63:63
62-Door, electric, left/right -- Status: Intermittent communication error 1000.
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BÀume, und die BlÀtter rascheln leise. Es ist ein wunderschöner Tag, um spazieren zu gehen oder ein Picknick im Park zu machen."
Address 09: Body Control Module. Label file: RKS\3C0-937-049-30-H.lbl.
Part number SW: 3C0 937 049 AJ, HW: 3C0 937 049 AJ.
Component: On-board network module H54 2202.
Revision: 00H54000 Serial number: 00000000699446
Encoding: E78B8F2701041500470000001C00000000097F075C000100000000000000
Operating number: WSC 45608 136 98486
VCID: 71C682601139
Part number: 1K1 955 119 E
Part: Wiper 080807 020 0501
Encoding: 00038805
Operating number: WSC 45608.
Part number: 1K0 955 559 AB
Component: RLS 230607 020 0105
Encoding: 00471077
"One error found:"
01333 - Rear left door control unit (J388)
004 - No signal/communication - Intermittent.
Environmental conditions:
Error status: 00100100
Error priority: 2.
Error frequency: 1.
Lost count: 11.
Mileage: 42385 km
Time: 0.
Date: 2005.09.13
Time: 31:63:63
aus
Voltage: 12.90 V
aus
one
aus
"aus" translates to "from" in English.
Address 19: CAN Gateway
Label file: RKS\1K0-907-530.lbl
Part number SW: 1K0 907 530 N, Part number HW: 1K0 907 951.
Component: J533 Gateway H06 0052
Revision: H06 01, Serial Number: 120607F1001877.
Encoding: ED817F4E000A032002
Operating number: WSC 32573 146 95222
VCID: 32444D6CD4BF
"One error found:"
Error status: 00110100
Error priority: 2.
Error frequency: 1.
Lost count: 10
Mileage: 42385 km
Time: 0.
Date: 2000.00.00
Time: 16:46:45
Address 62: Door electric, high/low. Label file: RKS\1K0-959-703-GEN3.lbl.
Part number SW: 1K0 959 703 P, hardware number: 1K0 959 795 G.
Component: J388 DOOR-SG HL 1120
Revision: 11006001 Serial number: 00000001981142
Encoding: 0000144
Operating number: WSC 00066 000 00000
VCID: 3D5E6E501DE1
No errors found.
The company announced record profits for the last quarter.
Log-KA-HK 556-WVWZZZ1KZ8M320904-42530km-Kohl20.txt
 File name:  Log-KA-HK 556-WVWZZZ1KZ8M320904-42530km-Kohl20.txt
 File size:  11.59 KB
 Downloaded:  1790 times
Translated on 25-10-2026, 22:30.
Post21-06-2011, 19:15    Subject: Hi-Li Door: Sporadic Communication Error 1000 Quote
Sporadic errors are always bad because they only occur sporadically, and, according to Murphy's Law, they never appear when you're trying to troubleshoot them.
Checking the cable routing through the door frame and B-pillar is another suggestion; look for any signs of a broken cable.
Translated on 25-10-2026, 22:38.
hkss
Avatar-hkss
2017 Skoda Yeti
Post22-06-2011, 19:53    Subject: Hi-Li Door: Sporadic Communication Error 1000 Quote
dieselschrauber wrote:
Sporadic errors are always bad because they only occur sporadically, and, according to Murphy's Law, they never happen when you're trying to troubleshoot them.
Best regards, Rainer
Hello Rainer, - thanks for the tip.
I had the CAN gateway updated at the workshop.
I provided the reference with the process number: (TPI) 2018677/11 icon_wink.gif.
Old:
Please provide the text you would like me to translate from German to English.
Part number SW: 1K0 907 530 N, HW: 1K0 907 951.
Component: J533, Gateway, H06 0052.
Revision: H06 01 Serial Number: 120607F1001877
VCID: 32444D6CD4BF
Now available:
Bitte gib mir den deutschen Text, den du ĂŒbersetzt haben möchtest.
Part number SW: 1K0 907 530 AE, HW: 1K0 907 951.
Component: J533, Gateway, H06 0112.
Encoding: ED817F4E000A03002002
Operating number: WSC 64319 136 186795.
VCID: 6AF4950C3CEF
And I haven't had any errors for a few days now.
Often, software updates also adjust or increase the timing parameters.
Let's hope that was it.
Translated on 25-10-2026, 22:41.
No new posts Passat 3B: Intermittent GRA Failure Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 3B Rear Door Won't Open? Transmission, Chassis, Body & Interior
No new posts Passenger Door Electric Failure: Common Causes & Fixes On-Board Diagnostics (OBD)
No new posts Audi A4: Rear Left Door Won't Open? Transmission, Chassis, Body & Interior
No new posts A6 2.5 TDI: 1000+ Common Problems & Fixes Diesel Engine Technology
