Performance issues and smoke from AHH motor
homa
Post15-07-2011, 18:39    Subject: Performance issues and smoke from AHH motor Quote
Hello everyone,
My father drives a Passat 3B5, model year 2000, with an AHH engine and approximately 195,000 kilometers on the odometer. Recently, he's been experiencing a problem where, at approximately 1900-2000 RPM, for example in 3rd gear, the power momentarily drops, a cloud of smoke comes out of the exhaust, and then the power slowly returns.
Generally speaking, one might feel that something is lacking in overall performance.
I have VAG Com in the free version, and the error memory is empty.
The air filter and diesel filter were once replaced as a test, but they eventually needed to be replaced anyway icon_wink.gif.
I carefully cleaned the mass airflow sensor with brake cleaner, but it didn't work. I've had success with that method on my old 1Z before. Would this error code appear in the error memory if something was defective?
I once read that you could temporarily replace the mass airflow sensor with a resistor to diagnose a potential defect, but I'm not sure if that's still accurate.
I would be grateful for any advice.
Martin.
Post15-07-2011, 19:53    Subject: Performance issues and smoke from AHH motor Quote
I own VAG Com in the freeware version
Unfortunately, I don't think I can help with that. The minimum requirement would be VCDS Lite, and having access to live data would also be helpful.
JSPatrick
Registered VCDS User
Post24-07-2011, 15:11    Subject: Performance issues and smoke from AHH motor Quote
Check if the AGR valve is closing!
Boost pressure is definitely a topic!
Is the LL system down?
I don't know what your VAG Com can do, but it should have a diagnostic data display, right?
You can also see the boost pressure there; the 11 series shows the target and actual pressure. If you go further...
You can narrow it down once you figure out what it is.
Best regards, Patrick.
No new posts AJM Engine: Rattling, Power Loss, Black Smoke Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AFB Engine Overview Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 2.0 TDI Engine Coolant Leak Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts White/Gray Smoke BKN 3.0 TDI Engine at Partial Load Diesel Engine Technology
This topic is locked, you cannot edit or reply. 2.0 TDI - Germany - Engine misfiring, white smoke Diesel Engine Technology
No new posts Engine RPM Limited to 3000, Excessive Smoke Diesel Engine Technology
No new posts TDI AFN Engine: Starting Issues, White Smoke, Misfire Diesel Engine Technology
