Starting problem Golf IV 110PS
sonic
Post13-07-2003, 20:17    Subject: Starting problem Golf IV 110PS Quote
Hello!
I'm experiencing some issues with the starting behavior of my Golf.
Symptoms:
- Occasionally starts up slowly, regardless of temperature.
- Start time is frequently up to 4 seconds.
(No issues with the operation of the vehicle.)
'From fuel filter to voltage supply relay, to control-start sequence (error memory cleared)... everything has already been checked/replaced.'
I've noticed that a larger air bubble becomes visible in the intake manifold a few seconds after the engine is turned off.
Maybe someone has some tips for me...
greetings
Post13-07-2003, 20:21    Subject: Starting problem Golf IV 110PS Quote
Hi.
Try opening the fuel tank cap; it might be due to a vacuum inside the tank.
Otherwise:
(read thoroughly)
Julian
Post13-07-2003, 21:46    Subject: Starting problem Golf IV 110PS Quote
Let's measure the battery capacity; if it's slowly degrading, it can cause problems with the TDI engine starting. 'The same thing suddenly happened to my TDI_90.'
With a new battery, it then ran like it did on the first day.
sonic
Post20-07-2003, 17:47    Subject: Starting problem Golf IV 110PS Quote
Thank you for the tip...
Put in a new battery and it's working!
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 5 1.4 BUD Misfire 2. Cylinder Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Golf V/VI and similar models: ABS/ESP error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Heated Seats VW Golf IV TDi 110PS Transmission, Chassis, Body & Interior
No new posts Golf IV TDI 110PS: What's the value? Diesel Engine Technology
No new posts GTI TDI Timing Belt Pulley Issue: Broken on KW? Diesel Engine Technology
No new posts Golf 2.0 TDI 110hp - boost pressure too high at partial load Diesel Engine Technology
