Opel Astra G won't start - Troubleshooting.
enzer200
Registered VCDS User
Post02-08-2011, 16:38    Subject: Opel Astra G won't start - Troubleshooting. Quote
"Hi, I have an Opel Astra G CC with a 1.7L DTI 16V engine with 75 horsepower. It suddenly stopped running and hasn't started since. There's an error code stored in the diagnostic system that I can't clear. The code is P1690, which indicates a low voltage issue in the engine control system.
I've read that it could be the high-pressure pump. When I open the fuel line on the high-pressure side, no fuel comes out when I try to start the engine. I've now manually supplied fuel to the fuel rail after the filter, but still no fuel reaches the injector. I've also disconnected the pump control unit and checked the power supply and ground connections, and they seem to be okay.
Has anyone else experienced this problem before? It would be great if you could help me."
Thank you. Best regards.
Translated on 20-10-2026, 12:15.
Post02-08-2011, 18:19    Subject: Opel Astra G won't start - Troubleshooting. Quote
Can you extract more information about the error? For example, can you convert it into a VAG error code, or identify any related pending errors?
The only thing I can think of is an electrical problem.
Translated on 20-10-2026, 12:16.
pax
Avatar-pax
2000 Volkswagen Passat
Post02-08-2011, 19:49    Subject: Opel Astra G won't start - Troubleshooting. Quote
Perhaps this will help you?
/viewtopic.php?t=21426
Bye.
peace
Translated on 20-10-2026, 12:17.
enzer200
Post03-08-2011, 22:17    Subject: Opel Astra G won't start - Troubleshooting. Quote
Hi, thanks for your efforts. Today I removed and opened the diesel pump control unit, and sure enough, there was a faulty solder joint at the second solder point of the red/blue input cable on the circuit board. I cleaned it, resoldered it, installed it, and it's working perfectly.
Thank you, keep up the good work. Best regards.
Translated on 20-10-2026, 12:18.
pax
Avatar-pax
Post03-08-2011, 22:26    Subject: Opel Astra G won't start - Troubleshooting. Quote
See, I saved 1200 euros – that's roughly the amount the Opel workshop quoted in the year 200x before I started working on the car myself.
Bye.
peace
This topic is locked, you cannot edit or reply. Pa 3C BMR Won't Start: Error Code 004160 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Engine won't start, Mj 1999 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine won't start, cranks after start attempt Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Opel Astra-H, first gear won't engage Transmission, Chassis, Body & Interior
No new posts Opel Astra 2008: Specs, Review & Price On-Board Diagnostics (OBD)
No new posts Opel Astra 1.7tds Diesel Pump, 1996 Diesel Engine Technology
No new posts Opel Meriva 1.4 gasoline engine (Z14XEL) doesn't start wh... Gasoline Engine Technology
