RNS Radio Issues: Troubleshooting & Solutions
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
Kerminator
Post16-06-2003, 11:06    Subject: RNS Radio Issues: Troubleshooting & Solutions Quote
Hello everyone,
'Does anyone else experience the problem where the car radio briefly turns off during the starting process, and then, after it turns back on (often when it's hot, like it is now), there's no sound? It's almost as if it's cursed. You can manually turn the radio on and off, but that usually doesn't help. Sometimes, only after restarting the car (sometimes multiple times) does the sound come back! Does anyone have a solution for this?'
Michael.
Translated on 25-07-2026, 12:24.
Marco
Post30-06-2003, 22:40    Subject: RNS Radio Issues: Troubleshooting & Solutions Quote
Da es sich um ein Blaupunkt Navi RNS 149 oder 150 handelt (Die haben einen aktiven Lüfter) solltest Du prüfen ob der Lüfter des Radios freie Bahn hat. DeFan outlet.
The radio's power button is located on the top right side of the back.
Translated on 25-07-2026, 12:25.
Marco
Post30-06-2003, 22:57    Subject: RNS Radio Issues: Troubleshooting & Solutions Quote
Just a small addition: Unfortunately, you didn't mention which car you have. For example, in a G4 with the 'Radio Gamma' equipment, pins 3 (self-diagnosis) and 5 (control signal for anti-theft system) should be removed from the compact connector and placed somewhere isolated. Furthermore, the radio should be connected to a constant power supply (+12V).
to prevent the excessively small microswitch from burning out due to...
To prevent ignition problems, please check if the warning sound is still working. If not...
Is it a fairly reliable indicator that pins 3 and 5 are still present in the connector?
Translated on 25-07-2026, 12:26.
Kerminator
Post01-07-2003, 7:29    Subject: RNS Radio Issues: Troubleshooting & Solutions Quote
I think I made a mistake. The navigation radio is not called 'Gamma,' but rather MCD (monochrome display). The vehicle is a Golf 4 (manufactured in November 1999) station wagon with a TDI engine. I hope you can use this better information to help me solve my problem.
Michael.
Translated on 25-07-2026, 12:27.
Marco
Post01-07-2003, 12:09    Subject: RNS Radio Issues: Troubleshooting & Solutions Quote
The VW Gamma is not a navigation radio; I only used it as an example to illustrate a possible connector configuration that would not be compatible with non-factory radios.
Now things are slowly becoming clearer; it's not a Blaupunkt RNS unit, but rather...
Was was the VW navigation system with MCD (presumably referring to a specific feature or brand) originally installed in the car from the factory?
Translated on 25-07-2026, 12:28.
Kerminator
Post01-07-2003, 13:02    Subject: RNS Radio Issues: Troubleshooting & Solutions Quote
The radio is standard equipment in my Golf.
Michael.
Translated on 25-07-2026, 12:29.
Post02-07-2003, 16:53    Subject: RNS Radio Issues: Troubleshooting & Solutions Quote
Hi, I have the MFD (the one with the color monitor). This error has occurred for me before. It's probably not the same issue, since the devices are different. Since I tried diagnosing the radio using VAG Com, I haven't had any problems anymore. The display then showed "Diagnosis..." (But I didn't change anything there, nor could or wanted to). Check in the navigation forum; I'm quite sure that there is a new (more current) software available for your navigation system, since it's from 1999. Such an update really makes sense. You can download it in that forum and then install it using the very clear instructions provided. Here's the link http://www.navi-projekt.de/; they are really knowledgeable there.
Matthias.
Translated on 25-07-2026, 12:30.
flaufer
Post21-07-2003, 16:53    Subject: Navigation Update for Car (1999) Quote
You can download it from the forum and then install it using the very clear instructions. Here's the link http://www.navi-projekt.de/. They are really knowledgeable there.
Matthias
Does anyone know if there are simple software updates available for the standard navigation system in Audi vehicles (model year 2000, without a color display, only displaying information in the FIS)? I often experience corrupted characters and symbols, and sometimes even crashes.
Felix.
Translated on 25-07-2026, 12:32.
No new posts Doku Golf 5, Lautstärke am Radio defekt Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku A3 8L bis KW 04/2002, Radio schaltet nicht mehr ein Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A2 Radio: Won't Turn On After Parking? (8Z0) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Car Radio Issues: Problems When Starting Engine Diesel Engine Technology
No new posts Problem mit GALA und NAVI-Durchsagen mit RNS-D im A4 8E Transmission, Chassis, Body & Interior
No new posts Kann man eigene POIs in die NAVI-CD einbauen? Diesel Engine Technology
No new posts New small Avatar Upload
