Differential Pressure Sensors CFBG
brezelmann01
Post19-08-2011, 19:55    Subject: Differential Pressure Sensors CFBG Quote
Hello!
Today, I took a closer look under the hood. I noticed something about the DPF:
I found a total of three temperature sensors: one BEFORE the turbo, one BEFORE the DPF, and one AFTER the DPF. That seems okay. What struck me as odd was the differential pressure. I only found one connection point BEFORE the DPF, which was connected to the sensor. The other side of the sensor was connected to atmospheric pressure. Is that normal? It also looks like the connection AFTER the DPF is blocked with a blind nut.
Here are some photos of the sensor and the blind nut.
 Differenzdrucksensor (versteckt hinter dem Halter)
 File size:  1.51 MB
 Viewed:  22472 times
 Blindstopfen nach DPF
 File size:  1.09 MB
 Viewed:  6796 times
Translated on 23-09-2026, 15:41.
Post19-08-2011, 20:22    Subject: Differential Pressure Sensors CFBG Quote
Probably, the engine control unit simply estimates the pressure after the DPF. icon_wink.gif The advantage is that it saves a piece of pipe and a hose compared to a software function.
It might be sufficient to use a model that incorporates engine speed, fuel injection volume, and intake air mass to "estimate" sufficiently accurate values.
Translated on 23-09-2026, 15:42.
vwSchrauber
Post19-08-2011, 21:24    Subject: Differential Pressure Sensors CFBG Quote
I agree. The engine control unit (ECU) already has an atmospheric pressure sensor, and the resistance from the DPF outlet to the exhaust pipe is calculated based on a model.
Translated on 23-09-2026, 15:43.
No new posts Differential pressure sensor G450 to be calibrated/adjust... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts DPF differential pressure sensor output voltage Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P2453: DPF Differential Pressure Sensor Error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Rattle Noise CR TDI CFBG Engine - Diagnosis Diesel Engine Technology
No new posts Differential Pressure Sensor: Explained Diesel Engine Technology
No new posts Differential Pressure Sensor T5 On-Board Diagnostics (OBD)
No new posts Differential Pressure Sensor Diesel Engine Technology
