AWX is not starting - further troubleshooting steps?
vwSchrauber
Post29-08-2011, 12:52    Subject: AWX is not starting - further troubleshooting steps? Quote
I'm having a problem with an AWX that won't start up after being shut down.
So far checked:
- Tax timings
- Fuel supply directly from containers
- Ventured under vacuum
- The PDE receives a control signal, which activates the magnetic valves.
- New submersible pump
- Initial dose of 50mg is displayed, as well as the duration of treatment.
- Angular offset KW/NW -1.6°
- Camshaft not misaligned with camshaft sprocket
- Starting RPM is okay, engine running with brake cleaner
- Compression OK
- PDE upgraded, seals replaced
Do you have any other ideas?
Post29-08-2011, 13:13    Subject: Re: AWX doesn't start - further troubleshooting steps? Quote
Lid?
Post29-08-2011, 13:29    Subject: AWX is not starting - further troubleshooting steps? Quote
Have you ever measured the pressure in the tandem pump?
Post29-08-2011, 13:38    Subject: Re: AWX doesn't start - further troubleshooting steps? Quote
vwSchrauber wrote:
AWX doesn't turn on after being shut down.
How long does this "after shutdown" state last?
vwSchrauber
Post29-08-2011, 14:34    Subject: AWX is not starting - further troubleshooting steps? Quote
Rear door?
open.
Is neu, werd ich jetzt aber mal machen.....what is the target value for starting speed (approximately 270 1/min according to VCDS)?
How long does this state "after turning it off" last?
vwSchrauber
Post29-08-2011, 15:23    Subject: AWX is not starting - further troubleshooting steps? Quote
I have thoroughly bled the system again (creating a vacuum on the return line, starting), and I have used brake cleaner to assist, and it is now running icon_smile.gif
The likely cause is a combination of factors: the VFP (which I disassembled), and the compressed seals (between the inlet and return channels) on the PDE.
Deus Violentia
Post29-08-2011, 17:15    Subject: AWX is not starting - further troubleshooting steps? Quote
BKD GRF
AHF EBF
Post29-08-2011, 19:20    Subject: AWX is not starting - further troubleshooting steps? Quote
vwSchrauber wrote:
Hopefully, the brake cleaner didn't cause any permanent damage... ?
The likely cause is a combination of worn VFP (I disassembled it) and compressed seals (between the inlet and outlet channels) on the PDE.
You already replaced the PDE seals (-> first post)?
Was he then still dependent on the auxiliary pump of the fuel tank (VFP)?
How did you determine the shrinkage of the O-rings?
Is there a special explanation for this in this case, or can the fun bloom for every 1.9 PD driver sooner or later?
How old is the car? Distance covered?
vwSchrauber
Post30-08-2011, 11:22    Subject: AWX is not starting - further troubleshooting steps? Quote
You already replaced the PDE seals (-> original post)?
Yes, but it only started after thorough depressurization and the use of brake cleaner.
I use brake cleaner instead of Startpilot because it burns much more gently, or rather, ignites later. Silicone spray also works, and you can even run the engine for a few seconds if you spray it while it's running, but I don't like the smell...
Now I also know why: the DiFi was at the top of the compression and was leaking, allowing air into the system when the engine was running.
In combination with worn VFP and shrunken seals, it simply wasn't enough to start the engine, or the battery was dead before the air was purged from the system.
How did you determine the O-ring shrinkage?
They were quite hard, and had hardly any overhang. The red (ancient) ones were still there. The upper seals towards the engine oil were still okay.
EZ 2001, approx. 190,000 km.
Post30-08-2011, 11:37    Subject: AWX is not starting - further troubleshooting steps? Quote
No new posts Document: V6 TDI engine won't start on a downhill slope Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Audi A4, Engine not starting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Parking Heater Not Starting: A6 4B Remote Issue Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Car Repair Problem? Get Expert Help Now! Diesel Engine Technology
No new posts G3 AFN Power Loss: Troubleshooting Guide Diesel Engine Technology
No new posts OIL PRESSURE SENSOR: Mechanic Stumped - Scandal! Diesel Engine Technology
No new posts Audi 1Z Power Loss: Troubleshooting & Solutions Diesel Engine Technology
