T4 Climatronic: Climate Control System
chriskross
Post06-09-2011, 8:23    Subject: T4 Climatronic: Climate Control System Quote
Hi!
I'm having a problem with a T4 long wheelbase van equipped with Climatronic. Specifically, I can't adjust the temperature or fan speed for the front and rear vents.
"If I unplug the white connector from the Climatronic control unit, I can adjust the temperature and fan speed."
I've already replaced the blower motor and the blower motor control module, as well as the resistor for the rear fan.
Error memory is empty.
"When I try to make a diagnosis using the Stellglied function, I receive a message indicating that the function is not supported."
Does anyone have a suggestion for me?
Best,
Chris
A6 AFB
A6 BRE DPF
Translated on 24-10-2026, 9:32.
No new posts Climatronic Error: Doku Sharan 7M8 Fix Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error code Climatronic 3B, model year 1999, 2000 model Troubleshooting & Guides
No new posts Reading Faults - VW Climatronic from Hella Troubleshooting & Guides
No new posts Log Climatronic Upload
No new posts Climatronic G3 TDI Transmission, Chassis, Body & Interior
No new posts Climatronic Error 214: Troubleshooting Guide On-Board Diagnostics (OBD)
No new posts Climatronic Coding: How to Program Your Car On-Board Diagnostics (OBD)
