Peugeot 206 HDI: Won't Start After Sitting?
chli1976
Post23-09-2011, 12:11    Subject: Peugeot 206 HDI: Won't Start After Sitting? Quote
I have a Peugeot 206 HDI that doesn't start after being parked for a while.
If you then pump the bellows where you bleed the air, it will start working again.
I checked the pipes and can't find any leaks anywhere.
"Are those plastic pipes and quick-release connectors? If they were made of rubber, I could just clamp them off."
Does anyone here have any experience with this?
Is there a leak somewhere?
I would most likely suspect the bellows.
VCDS
Translated on 02-10-2026, 3:34.
Karma: +1099 / -0   Thank you, like it!
Post23-09-2011, 14:45    Subject: Peugeot 206 HDI: Won't Start After Sitting? Quote
With a 99.9% certainty, it will be the fuel line bundle from the diesel filter to this air pump. However, it extends further from there. Theoretically, after a prolonged standstill, you should see one or more air bubbles in the short, transparent section of the line. As a temporary solution, manual bleeding will help, but in the medium term, the fuel line bundle needs to be replaced. So far, it is only available as a complete OEM part, including the inlet and outlet lines as well as the air pump. Please have a seat before we tell you the price of the replacement part!
The cause of the chafing is that the wiring harness is rubbing against its holders in two places due to vibrations from the engine. Before assembly, one could slide a piece of hose over the diesel lines at the corresponding points, but then they wouldn't fit into their holders. With some ingenuity, it should be possible to prevent the chafing or to secure the wiring harness in some other way without using the original holder. However, you would have to build something yourself. The lines are also difficult to access and not easily visible. Therefore, no one does anything proactively because they don't see the need.
Considering the price of the spare part and the relatively small additional cost for installation, it's worth considering having a trusted (Peugeot) workshop handle the job.
Translated on 02-10-2026, 3:36.
chli1976
Post23-09-2011, 15:24    Subject: Peugeot 206 HDI: Won't Start After Sitting? Quote
Okay, I'll take a closer look at that and inquire about the price.
VCDS
Translated on 02-10-2026, 3:38.
No new posts A2 Radio: Won't Turn On After Parking? (8Z0) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Review and Installation: Kenwood KDC-DAB 4551U in a Peuge... Troubleshooting & Guides
No new posts Touran GRA not working after TCU replacement Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts T4 ACV: Smoking After Standing - Troubleshooting. Diesel Engine Technology
No new posts TDI Engine: Hard Starting After Idle Time Diesel Engine Technology
No new posts VW Polo Starting Problems: 1.4L TDI PD Engine Diesel Engine Technology
No new posts BMW E90 320d: Starting Problems After Long Idle Diesel Engine Technology
