Audi A6 2.5 TDI: No Diesel - Troubleshooting
janbandit600
Post25-09-2011, 9:07    Subject: Audi A6 2.5 TDI: No Diesel - Troubleshooting Quote
Hello, I replaced the timing belt on my sister's Audi A6 with the 2.5 V6 AKN engine.
When I tried to prime the fuel lines by turning the ignition, I didn't hear the fuel pump running. I checked the circuit all the way to the engine control unit and found that the engine control unit wasn't providing a ground connection on pin 10 of connector 4.
I disconnected the wire from the engine control unit and manually provided a ground connection to the wire leading to the fuel pump relay, and sure enough, the pump started running. I disconnected the fuel line on the engine side at the filter, but still, no fuel is reaching.
Unfortunately, I'm at a loss. During the belt replacement, I disconnected the battery's ground cable. Now, when I reconnected it, the engine control unit and fuel pump seem to have failed?
I'm looking forward to hearing your ideas.
Thank you in advance.
Translated on 11-10-2026, 1:03.
Post25-09-2011, 11:13    Subject: Audi A6 2.5 TDI: No Diesel - Troubleshooting Quote
At AKN, this is not a pre-feed pump; it's a pump that only fills a suction chamber in the tank. It only starts operating when a certain tank level is reached.
Therefore, depending on your fuel level, everything is normal for you. icon_wink.gif
Translated on 11-10-2026, 1:05.
mserge
Post26-09-2011, 17:06    Subject: Audi A6 2.5 TDI: No Diesel - Troubleshooting Quote
...in other words, you need to "manually" bleed the system using a vacuum pump and a lot of patience. You can find the explanation using the search function. Bleeding instructions for AFB, AKN, and the simple V6 TDI engines.
neuer Turbo bei 200.000km
neue ESP bei 216.000km
verkauft mit 225000tkm
Clio 2 RS 170 PS BJ2003
Translated on 11-10-2026, 1:06.
No new posts Engine Idling Low: Troubleshooting & Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing belt replacement Audi A6 4F, BRE engine 2.0 TDI PD Troubleshooting & Guides
No new posts Audi A2 to A6, Engine Area, Generosity Policy Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi B7 Engine: Hard Starting / Diesel in Oil Diesel Engine Technology
No new posts No Diesel Cars: Compact & Mid-Size Cars After 2010 Diesel Engine Technology
No new posts Engine Won't Accelerate? Troubleshooting Guide. Diesel Engine Technology
No new posts Engine not consuming oil - Ford 1.3L, 1996, oil level ok Gasoline Engine Technology
