Praxiswerte: 0,216mm-Düsen im AFN | Posts 48+
Go to page: Previous  1, 2, 3, 4
vwSchrauber
Post28-09-2011, 12:51    Subject: Quote
Don't worry, it's fine just at the start, the system will compensate perfectly, as long as the pump isn't completely worn out.
@Rainer: I have to disagree with you – apart from the fuel injector replacement, we had several sluggish TDIs that, although they hadn't had any errors in the memory, still had the fuel injectors reaching their limit at full load + high RPM.
Early adjustment to the tolerance limit also resulted in a significantly improved response in the lower and middle load ranges.
I'm not entirely clear on why the manufacturer chose such a "flexible" rule characteristic with tolerant error margins. Perhaps to prevent oscillations in the control loop, and thus jerking and emergency shutdowns icon_question.gif icon_confused.gif
Post28-09-2011, 13:05    Subject: Quote
vwSchrauber wrote:
Don't worry, it's just at the beginning, the system will compensate perfectly, as long as the pump isn't completely worn out.
Yes, most of the time they are cars with more than 250,000 km. "That's not working properly either with the 'old' nozzles."
Hi, Rainer
vwSchrauber
Post28-09-2011, 13:30    Subject: Quote
Right - all were over 150,000, timing belt replacements in an "anonymous" workshop icon_lol.gif
No new posts AHF Nozzles: 0.232mm vs 0.216mm for Chips Diesel Engine Technology
No new posts Teilenummer Einspritzdüsen 2,5l 0,216mm Lochdurchmesser Diesel Engine Technology
No new posts 4 nozzles with NHG instead of 3 standard nozzles Diesel Engine Technology
No new posts ALH Injectors: Compatibility with AFN Engines? Diesel Engine Technology
