CR-TDI V6 2.7L: Adjustment Channels Not Working (Solution)
Post11-10-2011, 19:13    Subject: CR-TDI V6 2.7L: Adjustment Channels Not Working Quote
The differential pressure sensor and the DPF loading status cannot be adjusted via diagnostic adaptation for the 2.7L V6 CR TDI engine control unit.
Therefore, it is not possible to calibrate the differential pressure sensor or reset the ash mass of the diesel particulate filter.
Verified with engine control unit:
4F1910401B 2.7L V6 TDI G000SG 0030
Solution:
Update to software version 0060. See TPI 2012786/8, SVM code 4F01A016.
See also:
Engine control unit, new engine software, CD number, SVM (Software Vehicle Module).
4E0910402B, 4E0910402B_0040, 4E0906961Q, 4E01A009
0010 0020 0030
4E0910402C, 4E0910402C_0030, 4E0906961Q, 4E01A009
0010 0020
4E0910402G, 4E0910402G_0030, -----------------, 4E01A012
0020
4E0910402H, 4E0910402H_0020, --------, 4E01A012
0010
4F0910401S, 4F0910401S_0050, 4E090696Q, 4F01A016
0020 0030 0040
4F0910402E, 4F0910409C_0010, -----------------, 4F01A023
0010
Translated on 18-09-2026, 0:44.
Ratings - CR-TDI V6 2.7L: Adjustment Channels Not Working
No new posts General Audi customization channels Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Adaptation channels in TDI engines Troubleshooting & Guides
No new posts DPF not regenerating Troubleshooting & Guides
No new posts VCDS does not recognize Skoda Octavia; Gateway not supported On-Board Diagnostics (OBD)
No new posts 1Z fails to start/shuts down during operation (not relay ... Diesel Engine Technology
No new posts Glow Plug Not Turning Off? Engine Won't Start. Diesel Engine Technology
No new posts Car won't start, lights not working Diesel Engine Technology
