Auxiliary Relay for Blower & AC Control in Parking Heater?
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
findus170
Post30-10-2011, 21:00    Subject: Auxiliary Relay for Blower & AC Control in Parking Heater? Quote
Good evening, fellow diesel mechanics!
I'm currently installing an Eberspächer auxiliary heater in my Bora (engine code: ATD; with manual air conditioning).
Here's the problem I'm encountering: According to the attached instructions, why is a second relay required for the climate control system? (see diagram 4)
I would now only connect the blower to the relay as shown in diagram 3. What is the disadvantage of doing that?
Thank you for your responses!
Findus.
 File size:  154.83 KB
 Viewed:  5331 times
VW ID 7 GTX
Translated on 15-09-2026, 20:44.
brezelmann01
Karma: +75 / -0   Thank you, like it!
Post30-10-2011, 22:54    Subject: Auxiliary Relay for Blower & AC Control in Parking Heater? Quote
Hi Findus!
As I understand it, the second relay prevents the air conditioning from being turned on. In any case, the AC switch will definitely not light up (if it's pressed), and you might also have the problem that the radiator fans are activated (depending on how the electronics behind the VW switch are powered).
I only needed to install one relay with my Webasto TT-E in my Polo 6NF. But as I said... check how your vehicle is wired behind the switch!
pretzelman01
Translated on 15-09-2026, 20:46.
findus170
Post31-10-2011, 22:00    Subject: Auxiliary Relay for Blower & AC Control in Parking Heater? Quote
Okay, you're welcome!
VW ID 7 GTX
No new posts Engine and instruments fail - Relay 109? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P068A Error: Engine Won't Start (Relay J271) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW T4 AHY: Defective Auxiliary Heater / Parking Heater Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Blower Relay J323 - Replacement & Parts On-Board Diagnostics (OBD)
No new posts Auxiliary Heater VW T4 Fan Rear Transmission, Chassis, Body & Interior
No new posts 3B5: Troubleshooting and Common Issues On-Board Diagnostics (OBD)
No new posts Blower Resistor for VW Polo 9N Transmission, Chassis, Body & Interior
