chli1976 Profi-Schrauber
04-11-2011, 18:44 Subject: Passat NW worn out |
I have a Passat AVF with 250,000 km that's making a rattling noise and a dull "thumping" sound.
The dull "clattering" sound is clearly coming from the worn camshafts, as the valves are no longer opening completely.
When I accelerate, I hear a brighter noise, and I'm not 100% sure if it's coming from the valves that aren't opening, or if there's also a defect in the crankshaft mechanism.
The owner said the noise appeared suddenly, but it's good that it's a woman, although some people might notice if it gradually gets louder.
The owner doesn't want to invest as much money anymore, and the camshaft with the hydraulic lifters is also quite expensive.
Would you also replace the bearing shells of the NW (presumably referring to a specific engine or component)?
In MWB 13, only the 2-cylinder engine was noticeable.
What do you think about that?
Here's another video.
[url][/url]http://www.youtube.com/watch?v=eiLY3wKRmgU{MARKER}
| Description: |
| Ein gute Passat TDI Nockenwelle |
| File size: |
2 MB |
| Viewed: |
869 times |
| Description: |
| Eine der Passat TDI Nockenwellen mit verschlissenen Nocken |
| File size: |
2.05 MB |
| Viewed: |
1091 times |
VCDS
mullemaus Guest
04-11-2011, 19:50 Subject: Passat NW worn out |
Are you sure the squeaking noise only comes from the worn-out bearings? I would rather suspect the hydraulic components, as they are likely a major cause of the 'wear-related' noise. With that, and the wrong oil – it's all just a mess.
You can replace the NW bearing shells, as they usually wear out after 150,000 km.
Joined: 04/12/2002 Posts: 18119 Karma: +801 / -0 Location: St.Gallen 2018 Volkswagen T6
04-11-2011, 20:59 Subject: Passat NW worn out |
Most likely a valve mechanism, but unfortunately I can't really make out much from the pictures. Is there another version of the video available for uploading in the thread (for some reason, it wasn't made available that way)?
Profile PM WWW Garage |
04-11-2011, 21:47 Subject: Passat NW worn out |
mullemaus wrote: | Are you sure that the squeaking only comes from the worn-out wheel bearings? I would rather look at the hydraulic components, as I think they are largely responsible for the "wear-related" noise. With that, and the wrong oil – it's all just a mess.
You can replace the bearing shells of the NW engine; they usually wear out after 150,000 km anyway.  |
"Hydros" are naturally included.
VCDS
07-11-2011, 13:22 Subject: Passat NW worn out |
"The TPI report indicates quality deviations in the valve lifters and the camshaft."
VCDS
11-11-2011, 22:04 Subject: Passat NW worn out |
Today I installed new valve cover gaskets, tappet adjusters, and bearing shells, and now it's running smoothly again.
VCDS
11-11-2011, 22:11 Subject: Passat NW worn out |
Thank you for the feedback!
