Didi_n
Registered VCDS User
15-11-2011, 16:24 Subject: Audi A4 B5 AFN Voltage Problem |
Hello everyone,
I have a problem with my A B5 Avant 110PS TDI AFN. Maybe someone here has a tip for me, even though it's not a specific diagnostic problem right now.
The vehicle no longer starts, there are no warning lights illuminated on the dashboard, and nothing electrical seems to be working. However, the battery is not completely discharged, and neither does attaching a jump starter box make any difference. Also, even systems that don't rely on the ignition switch, etc., such as the hazard warning light system, do not function.
Does anyone have a possible solution?
Didi
DieselBär30x Profi-Schrauber
Joined: 01/17/2008 Posts: 3563 Karma: +101 / -0 Location: MĂźnchen & Passau
15-11-2011, 16:48 Subject: Audi A4 B5 AFN Voltage Problem |
Hi Didi!
Solution Approach: Use a measuring device to measure voltages!
Start with the battery and, if necessary, locate and fix any interruptions (especially the ground wire!).
Best regards from Munich! 1. S.verlängerung: Audi A4 Avant quattro, 1,9 TDi MKB: AFN, BJ98, Vollausstattung, +VP1L
3. T5 1,9 TDI PD (AXC), BJ04 - nur Ărger!
RedR32 Schrauber
Joined: 12/21/2008 Posts: 1071 Karma: +11 / -0 Location: Bad Lobenstein 1998 Volkswagen Golf Premium Support
15-11-2011, 17:09 Subject: Audi A4 B5 AFN Voltage Problem |
Interior locking, ignition switch, or (+) terminal of the power distribution box should be tightened.
To remove the cover under the steering wheel. 2010 Caddy kombi life 103 tdisg6 BMM KXW
reflexsilber met.
Profile PM Garage |
