Passat 3B: Horn Not Working - Repair Guide (Solution)
Michael II
Post28-07-2003, 9:24    Subject: Passat 3B: Horn Not Working - Repair Guide Quote
Horn does not function.
Cause.
Loose connectors.
2. Loose connection of the signal horn.
3. Contact problems caused by oxide buildup on the contact surfaces.
Solution:
Check the connections and fittings of the signal horn. If a malfunction of the signal horn is detected during the handover inspection, the horn contact should be activated several times (activation duration approximately 5-10 seconds).
If the function is still impaired, the signal horn should be replaced.
Tschüss
Michael II
Translated on 27-08-2026, 2:05.
Ratings - Passat 3B: Horn Not Working - Repair Guide
No new posts Passat 2000: Heated Mirror Not Working? (Troubleshooting) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A3 8L Mirror Defogger: No Function? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A3 8L: Frequency Display Not Working - Fix? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Non-Functional Horns and Fog Lights Diesel Engine Technology
No new posts Passat 3B GRA without function AFN Electrical Systems, Vehicle Electronics, Multimedia
No new posts Passat 3B, FFB+ Fensterheber+Interior lighting without fu... On-Board Diagnostics (OBD)
No new posts Passat: AHK Coding & AFS Issues On-Board Diagnostics (OBD)
