Drosselklappe - Fehler | Posts 16+
Go to page: Previous  1, 2
engl
Post15-01-2012, 12:09    Subject: Quote
When I first encountered the problem with the DK [device/component], I tried to find pictures showing what the part looks like, especially inside. Since I couldn't find any, I'm posting some photos here now, after having taken apart two of them; hopefully, it will help someone.
The screw in the cover acts as a stop for the drive shaft (DK), preventing it from re-engaging with the damaged gears. Unfortunately, it would probably also be necessary to remove and clean the motor, as it is still shorting out; this would require removing the DK shaft.
Okay, topic closed; part replaced.
'lg' translates to 'best regards' or 'kindly regards' in English. It is a common abbreviation used at the end of emails and letters.
 DK6
Man sieht, daß die DK nicht mehr ganz öffnet.
 File size:  130.56 KB
 Viewed:  35975 times
 DK5
 File size:  162.93 KB
 Viewed:  19421 times
 DK4
 File size:  110.93 KB
 Viewed:  57115 times
 DK3
 File size:  156.29 KB
 Viewed:  33039 times
 DK2
 File size:  249.07 KB
 Viewed:  19756 times
 Drosselklappe 1
 File size:  312.2 KB
 Viewed:  23510 times
Translated on 17-07-2026, 11:44.
RedR32
Avatar-RedR32
1998 Volkswagen Golf
Post15-01-2012, 15:31    Subject: Quote
What kind of nonsense is this now?
Error log entry remains definitely!
reflexsilber met.
Translated on 17-07-2026, 11:46.
engl
Post15-01-2012, 17:29    Subject: Quote
Okay, new throttle body module installed and that's it.
No new posts Throttle Body V157 Fault, P3103 Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Golf V/VI and similar models: ABS/ESP error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A5 throttle body Diesel Engine Technology
This topic is locked, you cannot edit or reply. Throttle Body Cleaning: T3 WBX (Solved) Gasoline Engine Technology
No new posts Polo 6N Throttle Body Initial Adjustment Gasoline Engine Technology
No new posts Adapt throttle valve Lupo 16V Gasoline Engine Technology
