chriskross Blaumann
Joined: 04/19/2006 Posts: 304 Karma: +3 / -0 Location: Österreich
24-01-2012, 18:14 Subject: Golf V: Squeaking Noise When Releasing Gas |
Hi!
I have a strange scratching noise on my Golf V with engine code BRU, 90 horsepower TDI, manufactured in 2006.
This happens when I release the accelerator pedal in 2nd or 3rd gear above approximately 3000 RPM, and it persists until around 2500 RPM. As soon as I press the accelerator pedal during this noise, it immediately stops.
"When accelerating, I don't hear any unusual noises, and the performance seems normal."
Does anyone have any ideas?
Best, Chris. A6 AFB
A6 BRE DPF
Translated on 16-09-2026, 20:57.
25-01-2012, 0:01 Subject: Golf V: Squeaking Noise When Releasing Gas |
Is that the "Kauder" model that also has (or is supposed to have) 105 horsepower?
There is a modified intake manifold designed to reduce noise.
There's a thread here with pictures about it... Transparency, Teamwork
Translated on 16-09-2026, 20:58.
Profile PM Garage |
chriskross Blaumann
25-01-2012, 9:39 Subject: Golf V: Squeaking Noise When Releasing Gas |
I suspect the noise is coming from the turbo. A6 AFB
A6 BRE DPF
Translated on 16-09-2026, 20:59.
voodoo Guest
25-01-2012, 10:59 Subject: Golf V: Squeaking Noise When Releasing Gas |
I'm experiencing a similar noise with my 8E.
It sounds similar to what you'd hear with a 1.8T engine equipped with a blow-off valve.
Such a sighing sound when the accelerator is suddenly released.
In my opinion, it sounds like the noise caused by airflow separation.
Hutfahrer Schrauber
Joined: 10/22/2005 Posts: 7824 Karma: +1099 / -0 Location: BAR
25-01-2012, 11:08 Subject: Golf V: Squeaking Noise When Releasing Gas |
"My car's diesel engine does the same thing. According to the Peugeot workshop foreman, it's just a design quirk and not a defect. The design of a part of the intake air system was changed when switching from the 8HX to the 8HZ engine (Euro 3 to Euro 4), which reduced the noise but didn't completely eliminate it." Automobile Zeitzeugen: |SUZUKI Swift Sport (2008)| |Smart 450 (2002)| |Honda CB 125 F (2018)|
Translated on 16-09-2026, 21:00.
chriskross Blaumann
25-01-2012, 19:59 Subject: Golf V: Squeaking Noise When Releasing Gas |
Okay, I'll leave it as it is for now.
They would probably say, "It's state of the art." A6 AFB
A6 BRE DPF
Joined: 04/12/2002 Posts: 18119 Karma: +801 / -0 Location: St.Gallen 2018 Volkswagen T6
25-01-2012, 20:36 Subject: Golf V: Squeaking Noise When Releasing Gas |
wav / mp3?
Translated on 16-09-2026, 21:01.
Profile PM WWW Garage |
