Golf V TDI 1.9 BLS: Performance Data & Specs
TDI-Driver1
Post23-01-2012, 17:39    Subject: Golf V TDI 1.9 BLS: Performance Data & Specs Quote
Since my car was experiencing a jerky motion and a lack of throttle response shortly after starting a few days ago, I am currently in the process of troubleshooting the issue.
The error occurred only once, approximately 3 times, each time at around 1500 rpm. I then drove at lower speeds, and on the next attempt, everything was normal.
No errors found.
Today I created a log file. The charging pressure seems to be okay, and the AGR value also corresponds to the expected value.
Maximum speed achieved: 196 km/h, calculated based on logged engine speed and gear ratio, and also acceptable in terms of power output.
"However, I would like to check the mass airflow sensor. Unfortunately, I can't find the target value (expected value) in either the main diagnostic data or the extended measurement data; I only see the actual value. Can anyone help me with this?"
What surprises me is that the AGR (Abgasrückführung) seems to be always open (at approximately 4000 rpm and 100% throttle position, but the target value is 85g/h), or am I interpreting the values incorrectly?
Golf V Goal 1,9 TDI DPF (105 PS) 6 Gang; MJ 06 4-Türer mit Climatronic, SRA, MAL, SzH, EFH, Znec 2011D, PDC, Codiert:CH, LH, US-Standlicht, Softtouch, Abbiegelicht Nachgerüstet: RLS, auto. ablendender Innenspiegel,RDK, Xenon, Standheizung orig TTV,
Golf V Variant Sportline 1.4 TSI (160PS) 7-Gang DSG; MJ09 mit Climatronic, SRA, MAL, SzH, EFH, Zenec 2011D, PDC v+h, CH, LH, Abbigelicht, Xenon, RDK, Panoramadach Nachgerüstet: RLS, auto. ablendender Innenspiegel, Standheizung original TTV
Translated on 11-10-2026, 7:22.
Post23-01-2012, 18:32    Subject: Golf V TDI 1.9 BLS: Performance Data & Specs Quote
Please include the Autoscan/Log in the "Uploading" section.
How many kilometers are on the engine?
Yes. Exhaust gas recirculation (EGR) does not occur at full throttle, but it does occur at partial throttle (see the duty cycle of the control signal in the relevant measurement block).
Translated on 11-10-2026, 7:24.
TDI-Driver1
Post23-01-2012, 18:58    Subject: Golf V TDI 1.9 BLS: Performance Data & Specs Quote
Okay, here's the translated text:
"Okay, coming right away. These are the logged data from about an hour ago."
If a graphical representation would be helpful, I can certainly create one later.
Yes, that's correct. "AGR" means the exhaust gas recirculation system is closed, meaning only fresh air is being used. Therefore, the value should be at its minimum, not its maximum. Am I misunderstanding something?
The engine has approximately 102,000 kilometers on it, and nothing has been cleaned yet (e.g., the EGR valve, intake manifolds, etc.).
"MFG" is an abbreviation for "Mit freundlichen Grüßen," which means "Sincerely" or "Best regards" in English.
Translated on 11-10-2026, 7:25.
Post23-01-2012, 19:14    Subject: Golf V TDI 1.9 BLS: Performance Data & Specs Quote
The relevant information is missing; please upload the log file itself... Your xls file seems to be more corrupted than processed... icon_cool.gif
Since it's almost 1MB in size and doesn't provide any useful information, I've gone ahead and removed it.
Translated on 11-10-2026, 7:26.
TDI-Driver1
Post23-01-2012, 19:24    Subject: Golf V TDI 1.9 BLS: Performance Data & Specs Quote
Okay, sorry. I hope this helps more.
Ansonsten werde ich ein neues log-file machen mit den hier empf. MWB.
LOG-01-018-023-036-088-098-107-116.CSV
 Rohdaten Log für BLS, sporadisch Aussetzer / keine Gasannahme
 File name:  LOG-01-018-023-036-088-098-107-116.CSV
 File size:  71.69 KB
 Downloaded:  778 times
Translated on 11-10-2026, 7:27.
Post23-01-2012, 20:02    Subject: Golf V TDI 1.9 BLS: Performance Data & Specs Quote
I've removed some unnecessary elements from the file. At least, that's what it seems like...
- that the turbocharger pressure regulation system is functioning correctly.
- The exhaust gas recirculation (EGR) and throttle valve seem to be okay, but unfortunately, the log doesn't include the duty cycle information.
100,000 km would be a reasonable mileage for a faulty throttle body/AGR module (due to a plastic gear breaking in the control mechanism).
Could you please check the readiness status?
Translated on 11-10-2026, 7:28.
TDI-Driver1
Post23-01-2012, 20:07    Subject: Golf V TDI 1.9 BLS: Performance Data & Specs Quote
Okay, thank you for your effort.
Well, I hope not, but some things are already starting to fail (rear wheel bearings, brakes are okay for now, but will need to be replaced soon).
Yes, I did, and I passed everything.
As I mentioned, I can log in again tomorrow if you have any suggestions.
What about the LMM target value? Does it no longer exist in the newer TDIs, or am I just mistaken?
Regarding my father's AV fistula, there's a specific value that's actually useful for checking the blood flow rate.
Translated on 11-10-2026, 7:30.
Post23-01-2012, 21:06    Subject: Golf V TDI 1.9 BLS: Performance Data & Specs Quote
See the target value for exhaust gas recirculation icon_wink.gif. However, the actual value is more interesting.
TDI-Driver1
Post23-01-2012, 21:23    Subject: Golf V TDI 1.9 BLS: Performance Data & Specs Quote
Oh icon_redface.gif.
Okay, now I understand some things. So, Exhaust Gas Recirculation (Actual) = Air Mass (Actual), and are the small differences in the log caused by the sequential sampling? icon_smile.gif
I will be recording the duty cycle tomorrow. Would the MWB 8 and 10 be useful for that, based on what I know?
Another question would be whether a preventative cleaning of the EGR valve, intake manifold, and intercooler piping is recommended. Perhaps someone has experience with how dirty TDIs typically get after 100,000 km.
The vehicle is primarily used for long-distance driving, mainly on country roads and highways, covering approximately 150 km.
Translated on 11-10-2026, 7:31.
Post23-01-2012, 21:37    Subject: Golf V TDI 1.9 BLS: Performance Data & Specs Quote
The small differences between the desired and actual values for air mass/EGR are caused by the control system and the temporal sampling differences. The actual value can never be 100% of the desired value. icon_wink.gif
The duty cycle is the 4th value in measurement block 3.
It's difficult to determine the optimal mileage for cleaning the intake system based solely on kilometers, as it depends heavily on the driving conditions.
Frequent short trips with light loads (resulting in a high AGR rate) and low operating temperatures lead to more deposits than longer trips with heavier loads.
"Proactively cleaning the intercooler pipes and turbocharger cooler is not really worthwhile. Perhaps you could clean the EGR valve after around 150,000 km, if you feel like it. As long as there are no problems, the benefit is rather limited."
Translated on 11-10-2026, 7:33.
TDI-Driver1
Post23-01-2012, 21:45    Subject: Golf V TDI 1.9 BLS: Performance Data & Specs Quote
Okay, thank you for all the explanations and tips.
Tomorrow, there will be another update with the new measurement values icon_smile.gif.
However, I now believe that I can ignore this occasional stuttering for the time being (wishful thinking?).
Translated on 11-10-2026, 7:35.
Post23-01-2012, 22:42    Subject: Golf V TDI 1.9 BLS: Performance Data & Specs Quote
"Let's keep this between us."
Translated on 11-10-2026, 7:36.
TDI-Driver1
Post24-01-2012, 19:14    Subject: Golf V TDI 1.9 BLS: Performance Data & Specs Quote
I logged in twice today. Once, the injection was MWB 18.23.7, and the second time it was MWB 3.8.10.
"I have another question: Does anyone have experience with the acceptable range for the fuel temperature measured by sensor G81? Yesterday, I saw a reading of 53 degrees Celsius above ambient temperature (which was 3 degrees Celsius). Could this potentially indicate a leak in the common rail pressure sensor between the fuel supply and return lines?"
24.01.12_2 BLS MWB 3,8,10.csv
 File name:  24.01.12_2 BLS MWB 3,8,10.csv
 File size:  367.83 KB
 Downloaded:  301 times
24.1.12_BLS MWB 18,23,7.csv
 File name:  24.1.12_BLS MWB 18,23,7.csv
 File size:  98.11 KB
 Downloaded:  286 times
Post24-01-2012, 19:43    Subject: Golf V TDI 1.9 BLS: Performance Data & Specs Quote
"Except for the spike, the log looks good from the perspective of potential errors. However, like your other logs, it doesn't provide much information."
It doesn't make much sense to always log the same conditions when the error doesn't occur.
If logging is to be done, it should ideally cover as many load states as possible, especially those where the error occurs.
If the "problem" doesn't appear directly in the log and is only occurring sporadically, I'm afraid you'll simply have to wait until the problem a) occurs more frequently/constantly or b) is logged in a way that it appears in the log and can be reproduced.
What happened to the readiness status?
PS: With PD injection, the fuel flows through the cylinder head, which is why it's perfectly normal to have slightly higher fuel temperatures.
 Spike im AGR Tastverhältnis. Sofern bei halbwegs gleichbleibenden Umgebungsbedingungen Spikes auftreten, spricht das für Regelprobleme.
Die Regelung versucht dann immer stärker den Sollwert zu erreichen und die Stellgrösse läuft weg.
 File size:  78.85 KB
 Viewed:  2138 times
Translated on 11-10-2026, 7:38.
TDI-Driver1
Post05-02-2012, 14:05    Subject: Golf V TDI 1.9 BLS: Performance Data & Specs Quote
Sorry, I was under a lot of pressure with exams, so I held off on responding.
As I mentioned, all readiness checks have been passed.
The problem hasn't occurred since then, so for me, it's resolved for now. I just wanted to make sure there wasn't an underlying issue.
Thanks again, Rainer, for your assessment.
Translated on 11-10-2026, 7:39.
No new posts Pierburg MAF Sensor: Fixing Low Readings Troubleshooting & Guides
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf IV 1.9 TDI AXR - Stutters under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Measurement values into EDC measurement blocks On-Board Diagnostics (OBD)
No new posts Measurement Data: Complete Removal? On-Board Diagnostics (OBD)
No new posts Strange readings Diesel Engine Technology
No new posts UDS Data: Hiding the Origin? On-Board Diagnostics (OBD)
