MWB 94: What temperatures are displayed?
flightmaster
Post05-02-2012, 19:39    Subject: MWB 94: What temperatures are displayed? Quote
Today, in freezing temperatures of -12°C, I checked all the temperatures, including the engine temperature (engine code BLS).
Here are the most prominent values.
Block 033.
0 /min Speed.
-18.0°C temperature ----> it was only -12°C.
989.4 mbar, Pressure.
5.69 g/s of air mass.
Block 094.
-12.0°C Temperature.
294.0°C Temperature -----> completely out of range. What temperature is that?
What temperatures are displayed in the two cases?
The values before and after the DPF were around ~0°C, even though the car had been parked for 2 days.
Thank you in advance.
Translated on 29-10-2026, 7:33.
No new posts MWB 94 & 33: Temperature Readings Explained Diesel Engine Technology
No new posts AAT with VP37: Key Values to Display On-Board Diagnostics (OBD)
No new posts Audi 2.5 TDI: Injection Timing Value Not Displayed Diesel Engine Technology
No new posts Will the Audi A4 B7 170 PS TDI engine have a problem? Bul... On-Board Diagnostics (OBD)
