Dieselfilter mit Knackfrosch sind was Tolles! - nur Ärger | Posts 16+
Go to page: Previous  1, 2
RedR32
Avatar-RedR32
1998 Volkswagen Golf
Post19-02-2012, 23:26    Subject: Quote
It appears that the 1.4 TDI AMF engine does not have an electric fuel pump (because I can't find a fuse for it),
Normally, you can hear the fuel pump when you turn the ignition on.
Most often, the unit installed in the tank, along with the fuel level sender, is called the "fueling unit." Take a look under the rear seat, behind the cover, and see how many wires are connected to the connector. If there are only 2 wires, it means only the sender is installed, and there is no pump.
reflexsilber met.
Translated on 02-09-2026, 13:47.
Olaf
Post20-02-2012, 9:28    Subject: Quote
I know. This is my second Lupo with an AMF TDI engine, and I've never heard a pump before. There's no fuse that controls it.
I also have pretty good hearing, and I can usually hear the fuel pump right away, especially in most VAG gasoline-powered vehicles.
In addition to that, there is no fuse, even though it is listed in the owner's manual.
I hadn't taken the lid off yet...
If the climate is a bit more pleasant...
Translated on 02-09-2026, 13:48.
Back to top Profile PM Email
jarobaldu
Karma: +40 / -0   Thank you, like it!
Post20-02-2012, 10:05    Subject: Quote
I have the Arosa with an AMF engine, and it also doesn't have a fuel pump in the tank.
Okay, I've been specifically looking for it, but so far I haven't heard any sound.
I had a leak due to defective O-rings in the differential.
/viewtopic.php?p=100491#100491
A.
AUDI A6 C4 1995 ABC/CRD
Fiat 124 Spider, Bj. 80
Translated on 02-09-2026, 13:49.
Mpire
Avatar-Mpire
2019 Skoda Octavia
Post21-02-2012, 15:48    Subject: Quote
Hello, I'd like to sign up as well icon_wink.gif.
According to the VW SSP documentation, the AMF has an electric pre-feed pump.
I've also replaced the DiFi (fuel injection unit) in a lot of PPD vehicles, and I haven't come across a single one without an electric fuel pump.
Here's the link to download the PDF document for the SSP (Service Information) related to the 3-cylinder PPD engines.
Regards, Mpire.
Translated on 02-09-2026, 13:50.
Olaf
Post21-02-2012, 15:50    Subject: Quote
The link to the SSP (Service Information) for 1.2 and 1.4 TDI engines works, but it's very slow.
As I mentioned in the other forum, the 1.2-liter engine is supposed to not have an auxiliary fuel pump, while the 1.4-liter engine should. The question is whether that statement is generally true...
Do you have a fuse for the pump in your Lupo?
Sure, we can move the discussion here; I think more people might be interested in it.
Translated on 02-09-2026, 13:51.
mullemaus
Post21-02-2012, 16:05    Subject: Quote
@Mpire - I have removed the link you provided that contains copyrighted VW documents.
If that happens again, I will suggest to Rainer that he gives you a break to think things over. icon_confused.gif
Translated on 02-09-2026, 13:52.
Mpire
Avatar-Mpire
2019 Skoda Octavia
Post21-02-2012, 20:27    Subject: Quote
mullemaus wrote:
@ Mpire - I have removed the link you provided, which contains VW documents protected by copyright.
If that happens again, I will suggest to Rainer that he might want to give you a break. icon_confused.gif
Okay, there was no malicious intent behind it, I just thought a link was simply a reference to another page.
Well, the link from the other forum has also been removed, so everything seems to be correct now.
Mfg Mpire
Translated on 02-09-2026, 13:53.
Olaf
Post23-02-2012, 16:30    Subject: Quote
I checked at the back. There are only 2 wires, so there's no pump.
Translated on 02-09-2026, 13:54.
RedR32
Avatar-RedR32
Post23-02-2012, 17:40    Subject: Quote
Many of the early PD engines do not have a fuel pump. In such cases, it's important to ensure that the tandem pump is filled to facilitate fuel intake. Some cars have a manual pump for this purpose, but this one doesn't.
Just fill the fuel filter completely, and it should work. Otherwise, something is leaking, and the pump is drawing in air.
reflexsilber met.
No new posts Subject: Extending Diesel Filter Replacement Interval Troubleshooting & Guides
No new posts L200 Problems: Common Issues & Solutions On-Board Diagnostics (OBD)
No new posts Boost Pressure Problems: N75 & Manifold Pressure Sensor Diesel Engine Technology
No new posts VNT15 AFN: Common Problems and Solutions Diesel Engine Technology
No new posts Clogged Diesel Filter? Diesel Engine Technology
