T5 AXD dumpfes poltern im Luftfilterkasten | Posts 16+
Go to page: Previous  1, 2
RedR32
Avatar-RedR32
1998 Volkswagen Golf
Post22-02-2012, 1:25    Subject: Quote
At the nozzle tip, you can see evidence that the parts have rubbed against each other.
reflexsilber met.
Translated on 31-07-2026, 21:02.
Post22-02-2012, 7:34    Subject: Quote
TDI-GTI-4-Motion wrote:
... with exceptions, for example, the BUK (6L Cupra TDI) definitely does not have glow plug monitoring.
chriskross
Post28-02-2012, 9:08    Subject: Quote
Hello!
I have now sanded and polished the scratches that can be seen in the pictures, following a tip from a motor repair specialist. He explained that these scratches would damage the sealing rings each time, preventing the fuel system from ever being completely sealed.
I'll try it one more time now; if that doesn't help, then a new ZK (likely referring to a component) will need to be installed icon_sad.gif.
Does anyone happen to know what residual pressure should be present at the tandem pump after the engine is turned off? I had 0.1 bar immediately after turning it off.
Can we potentially see if the system is leak-tight this way?
A6 AFB
A6 BRE DPF
Translated on 31-07-2026, 21:03.
chriskross
Post01-03-2012, 13:36    Subject: Quote
hi!
Unfortunately, it didn't help again.
Now the only question is whether to buy a head unit with PD (Plasma Display) elements for €4000.
or from the engine builder with cylinder head and valves but without PDE for €1800.
I took some logs once; what would you do with them?
LOG-01-013-014-023.CSV
 File name:  LOG-01-013-014-023.CSV
 File size:  29.56 KB
 Downloaded:  835 times
LOG-01-023-024-018.CSV
 File name:  LOG-01-023-024-018.CSV
 File size:  8.26 KB
 Downloaded:  451 times
A6 AFB
A6 BRE DPF
Translated on 31-07-2026, 21:04.
No new posts Audi A6 Avant: Noise from heating system Transmission, Chassis, Body & Interior
No new posts Air Filter Hose: Replacement & Installation Guide Diesel Engine Technology
No new posts Underbody tray & air filter box? Diesel Engine Technology
No new posts Air Filter Box for VW Golf 4 TDI Diesel Engine Technology
