Beurteilung Kipphebel / Nockenwelle eines T5 | Posts 16+
Go to page: Previous  1, 2
Karma: +590 / -0   Thank you, like it!
Post07-03-2012, 19:30    Subject: Quote
Hi!
I checked out the old, broken [device/machine] today. Watched ATJ.
The brake pads are absolutely brand new, even after 180,000 km.
A light, yellowish layer has accumulated along the edges.
It became visible after cleaning with isopropyl alcohol.
I think that when you write that no ridges can be felt,
the rollers likely do not distribute the weight evenly across the surface.
and the yellow streaks are residue from engine oil additives.
And you really emphasized that with your amazing photography.
If no ridges are felt, then there is no problem.
Deus Violentia
Post08-03-2012, 13:01    Subject: Quote
It would be interesting to see what happens if you use a P2500 abrasive cloth (like a Mirka Mirlon), dampen it with a little oil, and run it over the visible cutout. If those are indeed copper coatings, they should disappear within 30 seconds. If you need it, I can send you a sample for free.
BKD GRF
AHF EBF
Karma: +1344 / -0   Thank you, like it!
Post14-03-2012, 22:50    Subject: Quote
For image 2, I think of aniline dyes.
Image 1 and 2 show flow patterns. A view through the microscope, or even through a magnifying glass, will reveal the irregularities. The parts either dried out at some point or have a material/surface issue.
No new posts Einstellung der Einspritzdüsen/Düsenhalter eines VP-TDI Troubleshooting & Guides
No new posts TDI Injector Replacement: DIY Guide & Tips Troubleshooting & Guides
No new posts Repair of a VP37 manifold Troubleshooting & Guides
No new posts AFB Engine: Worn camshafts, broken rocker arms. Diesel Engine Technology
No new posts BKD 2.0 TDI: Log Evaluation & Diagnostics Diesel Engine Technology
No new posts Log for Assessment at BKD 2.0TDI Upload
No new posts AAZ camshaft (1.9 TD), 1Z camshaft (1.9 TDI)? Diesel Engine Technology
