Audi A4 electrical problem
gullianderle
Post21-03-2012, 8:36    Subject: Audi A4 electrical problem Quote
Okay, I'm also having a problem with an Audi A4, manufactured in August 2001, with the AWX engine. In this car, the turn signals, high beams, and power windows are no longer working. It's very suspicious that when you turn off the ignition, the radio should normally turn off. However, in this case, it remains on (possibly a faulty ignition switch?). The error indicates a communication failure with the steering column electronics.
I now need to find the wiring diagram and check the circuit for the window lifters and the light switch.
Post21-03-2012, 9:36    Subject: Audi A4 electrical problem Quote
Is the steering column electronics still accessible via diagnostics?
No new posts {SOUND_TYPE}: Rumble {VEHICLE_MODEL}: Audi A3 8P Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake fluid change Audi A4 8K Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Zuordnung Audi Typ, MKB, GKB, AKB, MJ Technical Data
No new posts T5 Electrical Problems: Troubleshooting & Repair On-Board Diagnostics (OBD)
No new posts Massefehler / Elektrikproblem an vielen Fronten Transmission, Chassis, Body & Interior
No new posts Wischermotor vorne Elektrikproblem Verkabelung Diesel Engine Technology
No new posts Audi 80 RS2 Steering Wheel Controls: Same as Audi A4 B5? Transmission, Chassis, Body & Interior
